OPTOEMU-PT600
OPTOEMU-PT600
OBSOLETE Auxiliary Box for OptoEMU Sensor with Stepdown Power Transformer & Fusible Disconnect
The OPTOEMU-PT600 auxiliary box is an optional accessory for the OptoEMU Sensor energy monitoring appliance.
In most installations, power for the OptoEMU Sensor is provided through a standard 120 or 240 wall outlet. However, if power is provided through another source, for example a monitored electrical panel, you will need the OPTOEMU-PT600 auxiliary box.
The box contains a transformer that takes input voltages between 220 and 600 VAC and transforms them to the 100-250 volts required by the OptoEMU Sensor. The box also contains a fusible disconnect for safety.
Note: This box is not intended for CAT3 installations.
Input voltage range
220–600 VAC line-to-line
Output voltage
110–240 VAC (power for OptoEMU-SNR-3V)
Fuses
1 amp, class CC, 600 VAC (Edison part number HCLR1)
Dimensions
6.0" w x 13.5" h x 4.5" d
Enclosure
Sturdy metal enclosure with standard knockouts for wiring
CE, RoHS, DFARS
30 months
* NOTE: Not intended for CAT3 installations.
OptoEMU Sensor 3V Data Sheet
The OptoEMU Sensor™ Energy Monitoring Unit monitors the electrical energy used in your facility and then delivers that data to online software applications, using your existing wired or wireless Ethernet network.
Energy data can also be incorporated into a control system, including the SNAP PAC System and systems communicating via Modbus/TCP or OPC. In addition, data can be sent to common SQL databases.
The OptoEMU Sensor gives you the detailed, real-time data you need to analyze energy consumption, manage use, and reduce energy costs.
OptoEMU Sensor User's Guide
The OptoEMU Sensor monitors energy usage in your facility so you can track energy data and reduce costs. This document describes how to install and use the OptoEMU Sensor and the optional auxiliary box.
