$525.00 (USA and Canada only)
Input Range
0 to 10 amp RMS AC/DC
Input Over Range
To 11 amps
Input Resistance
0.005 ohms
Maximum Input
11 amps AC/DC
Accuracy (AC)
±8 mA and ±0.2% reading
Resolution
400 µA
DC Reversal
±16 mA (0.16%)
Input Response Time (Step Change)
63.2% (6.32 A) in 50 ms 99% (9.92 A) in 75 ms
Data Freshness (Max)
0.025 ms
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB at 60 Hz
Maximum Operating Voltage Between Channels Common Mode Voltage
250 V 250 V
Isolation: Optical
4000 V
Isolation: Transformer
1500 V
Isolation: Channel to Channel
250 V continuous (1500 V transient)
Power Requirements
5 VDC (±0.15 V) at 200 mA
Ambient Temperature: Operating Storage
-20 °C to 70 °C -40 °C to 85 °C
Humidity
5-95%, non-condensing
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Wire size range
22 to 14 AWG
CE, RoHS, DFARS; UKCA
Lifetime
This document lists and describes all current Opto 22 SNAP PAC System part numbers, including PAC Project software, SNAP PAC controllers, and SNAP I/O modules of all kinds. SNAP PAC mounting racks and SNAP power supplies are also listed.
The isolated analog input modules described in this document are part of Opto 22's SNAP PAC System. They provide optical isolation, transformer isolation, and channel-to-channel isolation. This data sheet covers the following part numbers:
This document lists all Opto 22 part numbers that have the Underwriters Laboratory (UL) approval.
$515.00
$104.00
$110.00
$128.00
