SNAP-AIMA-iH
SNAP-AIMA-iH
OBSOLETE Isolated two-channel analog current input, HART communication, 4-20 mA
The SNAP-AIMA-iH provides two channels of isolated analog input current with a range of 4–20 mA and communicates with other Highway Addressable Remote Transducer (HART®) current loop devices. External loop power supplies are required for current loops.
Each channel features an integrated HART modem that allows the channel to communicate digitally with a HART FSK (frequency-shift keying) signal superimposed onto the analog 4–20 mA current loop. The channel is a master device when used together with SNAP PAC brains or controllers to communicate with other HART current loop devices in either point-to-point or multidrop configurations.
The SNAP-AIMA-iH is categorized by the HART protocol as a current input connection type, which means that the module is a low impedance device.
The module provides channel-to-channel isolation as well as transformer isolation and optical isolation. It is factory calibrated.
HART SNAP I/O modules are part of the SNAP PAC System. They mount on SNAP PAC racks alongside other SNAP I/O modules (analog, digital, and serial), so you have the combination of I/O you need at any location.
These modules require a SNAP PAC brain or rack-mounted controller for I/O processing and communications. They are not compatible with legacy brains and controllers.
HART SNAP I/O modules are designed for use with a SNAP PAC programmable automation controller and PAC Control automation software. Several HART-specific commands are available in PAC Control (version 9.4 and higher) for these modules. See the module data sheet for additional information. Sample PAC Control subroutines show you how to use commands to communicate with HART devices.
HART SNAP I/O modules can also be used without PAC Control. Use the SNAP PAC .NET HART developer toolkit to integrate HART SNAP I/O modules into an existing .NET/Mono application.
NOTE: If you need a HART output module, see the SNAP-AOA-23-iH.
Input Range
Nominal
Full
4 to 20 mA
3.2 to 24 mA
Maximum Survivable Input
40 V or 160 mA
Impedance
230 Ohms nominal
Resolution
0.8 microamps
Accuracy
+/- 10 microamps
Response Time
(% of span/delta I/delta time)
99.9%/20.7mA/10 ms
Gain Temperature Coefficient
30 ppm/ °C
Offset Temperature Coefficient
15 ppm/ °C
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB @ 60 Hz
250 V continuous
1500 V transient (1 s)
Isolation: Channel-Channel
250 V continuous
Power Requirements
5 VDC (+/- 0.15) @ 150 mA
Ambient Temperature:
 Storage
-20 °C to 70 °C
-40 °C to 85 °C
Humidity
5-95%, non-condensing
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
UL, CE, RoHS, DFARS; UKCA
Lifetime
HART SNAP I/O Modules Data Sheet
HART® SNAP I/O modules for analog current input and output provide communication with other Highway Addressable Remote Transducer (HART) current loop devices. This data sheet covers the SNAP-AIMA-iH input module and the SNAP-AOA-23-iH output module.
*** The SNAP-AIMA-iH and SNAP-AOA-23-iH are OBSOLETE and no longer available. ***
SNAP-AIMA-iH Module Firmware Readme
This README file lists revision changes made to the firmware used in SNAP-AIMA-iH (HART protocol) analog input modules.
HART SNAP I/O Modules User's Guide
This guide shows you how to install and use Opto 22's HART SNAP I/O analog input and output modules, either with PAC Control or in a custom program you develop. This guide covers the SNAP-AIMA-iH input module and the SNAP-AOA-23-iH output module.
HART Sample Subroutines for PAC Control Technical Note
This technical note describes how to install and use the HART (Highway Addressable Remote Transducer) Sample Subroutines for PAC Control. These subroutines allow Opto 22 controllers using PAC Control to communicate with a HART transmitter via an Opto 22 HART input module (SNAP-AIMA-iH).
Opto 22 Releases HART SNAP Analog I/O Modules
Opto 22 Releases HART SNAP Analog I/O Modules.
SNAP-AIMA-iH-r1.0d.eio
Module firmware for the SNAP-AIMA-iH (HART protocol) input module.
The HART (Highway Addressable Remote Transducer) Sample Subroutines for PAC Control allow Opto 22 controllers, using PAC Control to communicate with a HART transmitter via an Opto 22 HART input module (SNAP-AIMA-iH).
What’s included:
  • • 14 PAC Control subroutines—one subroutine for each of 14 universal HART commands
  • • An Example Chart using the subroutines
Once you've wired the HART device to the module and run the example strategy, you'll be able to communicate with the device.
Video: Securing SNAP Module
Video: Removing a SNAP Module
Video: Automation 101: Wire a Level Sensor
Learn how you can get accurate tank level readings plus HART data through this one level sensor, using just two wires.
Accuracy vs Resolution
