$434.00 (USA and Canada only)
Input Range
-1 mA to +1 mA
Maximum Over Range
±10% (=± 27500 counts)
Resolution
0.04 µA
Input Response Time (% of span/delta I/delta time)
99.9 %/19.9 µA/10 ms
Data Freshness
11 ms
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB @ 60 Hz
Maximum Survivable Input
11 mA or 28 VDC
250 V
Accuracy
0.05% (0.05 µA)
DRIFT: Gain Temperature Coefficient
30 PPM/ °C
DRIFT: Offset Temperature Coefficient
15 PPM/ °C
Isolation: Optical
4000 V
Isolation: Transformer
1500 V
Isolation: Channel to Channel
250 V continuous (1500 V transient)
Power Requirements
5 VDC (±0.15 V) at 200 mA
Input Resistance
5 K ohms (each channel)
Ambient Temperature: Operating Storage
-20 °C to 70 °C -40 °C to 85 °C
Humidity
5-95%, non-condensing
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Wire size range
22 to 14 AWG
CE, RoHS, DFARS
Lifetime
This document lists and describes all current Opto 22 SNAP PAC System part numbers, including PAC Project software, SNAP PAC controllers, and SNAP I/O modules of all kinds. SNAP PAC mounting racks and SNAP power supplies are also listed.
The isolated analog input modules described in this document are part of Opto 22's SNAP PAC System. They provide optical isolation, transformer isolation, and channel-to-channel isolation. This data sheet covers the following part numbers:
$104.00
$110.00
$128.00
