SNAP-AIVRMS-i
SNAP-AIVRMS-i
$478.00 (USA and Canada only)
SNAP Isolated 2-Ch 0-250 V RMS AC/DC Analog Input Module
The SNAP-AIVRMS-i module provides two isolated channels with an input range of 0 to 250 volts AC or DC. The SNAP-AIVRMS-i module may be used to monitor 120/240-volt AC/DC and 12/24/48-volt AC/DC system voltage and is ideal for differential voltage measurements.
The two channels are isolated from each other; they do not share any field connection.
If you do not need isolated channels, see SNAP-AIVRMS.
Input Range
0 to 250 V RMS AC/DC
Input Over Range
To 275 V
Input Resistance
1 megohms
Accuracy
±0.2 V and ±0.2% reading
Resolution
10 mV
DC Reversal
± 0.2 V (0.08%)
Input Response Time
(Step Change)
63.2% (158 V) in 50 ms
99% (248 V) in 75 ms
Data Freshness
0.025 s
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB @ 60 Hz
Maximum Operating
  Voltage Between Channels
  Common Mode Voltage
250 V
250 V
Isolation: Optical
4000 V
Isolation: Transformer
1500 V
Isolation: Channel to Channel
250 V continuous
(1500 V transient)
Power Requirements
5 VDC (±0.15 V) at 200 mA
Ambient Temperature:
  Storage
-20 °C to 70 °C
-40 °C to 85 °C
Humidity
5-95%, non-condensing
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Wire size range
22 to 14 AWG
CE, RoHS, DFARS
Lifetime
SNAP PAC System Product Guide
SNAP Isolated Analog Input Modules Data Sheet
The isolated analog input modules described in this document are part of Opto 22's SNAP PAC System. They provide optical isolation, transformer isolation, and channel-to-channel isolation. This data sheet covers the following part numbers:
CAD Drawing: SNAP I/O Module
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
