SNAP-B4
SNAP-B4
$405.00 (USA and Canada only)
SNAP 32-channel Pamux Protocol Digital Brain Board
Power Requirements
5.0 - 5.2 VDC @ 1.0A max.
(If Term1 installed add 0.5A)
Operating Temperature
0 C to 70 °C, 95% humidity, non-condensing
Communications Interface
Pamux Bus; two 50-pin connectors
Range: (Multidrop mode)
Up to 500 feet
LED Indicators
SEL (address selected), WD (watchdog timeout)
Jumpers
0 - 3
4 - 5
6
7
Address
Watchdog Timer Function
Reset Level
Effect of Reset on Channel 0 Watchdog
SNAP High-Speed Digital Brain Board Data Sheet
The SNAP-B4 is a high-performance digital I/O processor used to connect and control up to 32 channels of digital I/O using Opto 22's SNAP B-Series I/O mounting racks and the Pamux bus.
AutoCAD Drawings
PamScan for MS-DOS
PamScan for MS-DOS is a software utility for troubleshooting Pamux hardware.
Before you download, read the Legal Agreement.
PamScan for Windows 8/7/Vista (32-bit)
PamScan for Windows 8/7/Vista (32-bit) is a software utility for troubleshooting PAMUX hardware.
PamScan for Windows 8/7/Vista (64-bit)
PamScan for Windows 8/7/Vista (64-bit) is a software utility for troubleshooting Pamux hardware.
PamScan PCI for Windows XP/2000
PamScan PCI Windows XP/2000 is a software utility for troubleshooting PAMUX hardware.
