SNAP-B8M
SNAP-B8M
$162.00 (USA and Canada only)
SNAP B-Series 8-module Rack
NOTE: This rack is not suitable for SNAP PAC brains and rack-mounted controllers; see the SNAP-PAC-RCK8.
The SNAP-B8M rack mounts a compatible SNAP brain (such as the serial B3000 or the SNAP-UP1-ADS) and eight SNAP I/O modules. Analog, digital, and serial modules can be mixed on the same rack. The diagram at right shows the mounting rack populated with a SNAP Ethernet brain and compatible modules.
Field devices are wired directly to the top-mounted removable connectors on the SNAP I/O modules. The rack can be panel mounted or DIN-rail mounted and requires a 5 VDC power source.
SNAP I/O Racks
Part Number
Description1
Power2 Requirements
I/O Processor3 Compatibility
Replacement Fuse
Operating Temperature
Relative Humidity
SNAP-B4M6
4-module mixed
5.0 to 5.2 VDC @ 1.8 Amps max
SNAP-UP1-ADS
SNAP-B3000-ENET
SNAP-ENET-RTC
B3000
B3000-HA
SNAP-B4
SNAP-B6
SNAP-BRS
SNAP-BRS-HA
SNAP-B3000-
MODBUS
SNAP-FUSE4A
or Bel5 5HF4
0 to 70 °C
95%, non-condensing
SNAP-B8M6
8-module mixed
5.0 to 5.2 VDC @ 2.6 Amps max
SNAP-B8MC6
8-module mixed,
terminal block
SNAP-B8MC-P6
8-module mixed,
pluggable terminal block
SNAP-B12M6
12-module mixed4
5.0 to 5.2 VDC @ 3.4 Amps max
SNAP-B12MC6
12-module mixed4,
terminal block
SNAP-B12MC-P6
12-module mixed4,
SNAP-B16M6
16-module mixed4
5.0 to 5.2 VDC @ 4.2 Amps max
SNAP-B16MC
16-module mixed4,
terminal block
SNAP-B16MC-P6
16-module mixed4,
SNAP-D64RS7
16-module digital only (limited digital functions)
SNAP-UP1-D64
SNAP-ENET-D64
SNAP-PDPRS64
SNAP-FUSE1A
or Buss5 GDC1A
1 “Mixed” means the rack can hold analog, digital, and serial modules. Most Ethernet-based I/O processors handle all these types of modules; other processors do not. See the processor’s data sheet for details.
2 Power requirements shown are for a rack, a processor, and a full load of 2-channel analog modules (for the SNAP-D64RS, a full load of 4-channel digital modules). Power requirements for other SNAP modules are higher. See module data sheets.
3 “I/O Processor” means a SNAP brain or on-the-rack controller.
4 Four-channel SNAP digital modules can be used in positions 0–7 only.
5 Manufacturer’s part number (not available through Opto 22).
6 Agency Approvals include: UL, CE, RoHS, DFARS; UKCA
7 Agency Approvals include: CE, RoHS, DFARS; UKCA
SNAP Racks Assembly Instructions
SNAP I/O Racks Data Sheet
SNAP B-series mounting racks are designed to hold an intelligent SNAP I/O processor (either a SNAP brain or an on-the-rack controller) and several I/O modules.
This data sheet includes detailed information and specifications for SNAP B-series racks as well as the digital-only SNAP-D64RS rack. Rack fuses and DIN-rail adapters are also included in the data sheet.
B-series racks are used with serial and some Ethernet I/O processors.
  • With Ethernet processors such as the SNAP-B3000-ENET, B-series racks hold analog, digital, and serial modules.
  • With serial processors such as the serial B3000 brain, they hold analog and digital modules.
This document applies to these parts: NOTE: For racks to use with SNAP PAC brains and rack-mounted controllers, or with SNAP-UP1-M64 and SNAP Simple brains, see Form #1684, the SNAP PAC Racks Data Sheet.
SNAP-RCK-M2B Rack Adapter Installation Note
This note describes how to install the SNAP-RCK-M2B rack adapter, which allows a SNAP PAC rack-mounted controller or brain to be used on a legacy B-series SNAP rack. This note is applicable to these parts:
AutoCAD Drawings
CAD Drawing: Base for SNAP-B8M
This CAD file contains a drawing of the base of the SNAP-B8M mounting rack, which mounts SNAP I/O modules with a legacy brain or rack-mounted controller.
NOTE: For new development, we recommend SNAP PAC racks, brains, and controllers instead.
