SNAP-IAC-K-16
SNAP-IAC-K-16
OBSOLETE SNAP isolated 16-pt digital (discrete) input module, 70-130 VAC/VDC
The SNAP-IAC-K-16 senses on/off status for 16 channels of 70-130 VAC/VDC input. The module features automatic counting and latching and provides channel-to-channel isolation.
For field wiring, use the SNAP-HD-ACF6 wiring harness assembly with flying leads, or a SNAP TEX breakout board with a SNAP-HD-ACF6 cable.
The SNAP-IAC-K-16 cannot be used with legacy brains.
NOTE: If you need a similar module with a higher input voltage, see the SNAP-IAC-16 or the SNAP-IAC-A-16.
Reference Charts: Build your system in the SNAP I/O Configurator.
SNAP-IDC-16
SNAP-IDC-HT-16
SNAP-IAC-16
SNAP-IAC-A-16
SNAP-IAC-K-16
Input Range
10–32 VDC/VAC
15–28 VDC/VAC
90–140 VAC/VDC
180–280 VAC/VDC
70–130 VAC/VDC
Nominal Voltage Range
24 VDC
24 VDC
120 VAC
240 VAC
100 VAC
Input Resistance
44 K ohms
4 K ohms
300 K ohms
940 K ohms
220 K ohms
Logic Voltage and
Current
5 VDC ± 0.1 @ 150 mA
Input Arrangement
16 isolated input channels
Channel-to-Channel Isolation
250 V steady-state,
1500 V transient
250 V steady-state,
1500 V transient
250 V
250 V
250 V
250 V
250 V
Isolation: Field to Logic
1500 V
1500 V
1500 V
1500 V
1500 V
Maximum Number of HDD Modules on One Mounting Rack
16
16
16
16
16
Indicators
None; use optional OptoTerminal-G20 diagnostic display.
ON Voltage
10 VDC @ 0.230 mA
15 VDC @ 3.50 mA
90 VAC/VDC @ 0.3 mA
180 VAC/VDC @ 0.191 mA
70 VAC/VDC @ 0.3 mA
OFF Voltage
3 VDC @ 0.05 mA
9 VDC @ 2.0 mA
40 VAC/VDC @ 0.135 mA
40 VAC/VDC @ 0.043 mA
30 VAC/VDC @ 0.135 mA
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Polling time from I/O processor to module1
2–30 ms typical2
2–30 ms typical2
2–30 ms typical2
2–30 ms typical2
2–30 ms typical2
Input Turn-On/Off Time
15 ms turn-on time
20 ms turn-off time
20 ms turn-on time
25 ms turn-off time
15 ms turn-on time
20 ms turn-off time
15 ms turn-on time
20 ms turn-off time
15 ms turn-on time
20 ms turn-off time
Counting Frequency
(DC input)
0–25 Hz @ 50% duty cycle
0–15 Hz @ 50% duty cycle
Operating Temperature
-20 to 70 °C
-20 to 70 °C
-20 to 70 °C
-20 to 70 °C
-20 to 70 °C
Storage Temperature
-40 to 85 °C
-40 to 85 °C
-40 to 85 °C
-40 to 85 °C
-40 to 85 °C
UL, CE, RoHS, DFARS; UKCA
CE, RoHS, DFARS
CE, RoHS, DFARS
Lifetime
Lifetime
Lifetime
Lifetime
Lifetime
1 Affects turn-on and turn-off determination
2 Time varies based on the SNAP PAC I/O processor (brain or on-the-rack controller), processor configuration, and Ethernet host communication activity.
Modules, Cables, and Breakout Boards Compatibility Charts
This document shows which SNAP I/O modules, breakout boards, and cables can be used together.
Comparison Chart: SNAP 4-Channel and High-Density Digital Modules
This document compares 4-channel and high-density SNAP digital I/O modules.
SNAP PAC System Product Guide
SNAP High-Density Digital Modules Data Sheet
SNAP I/O high-density digital modules from Opto 22 provide 16 or 32 digital input or output points in one compact SNAP module. These modules are ideal for OEMs and others who have high point-count applications, or for anyone requiring more than 64 digital points on a single SNAP PAC rack. The high-density configuration reduces per-point costs of digital I/O systems by providing up to eight times as many I/O points in the same space.
SNAP high-density digital modules are part of the SNAP PAC System. They can also be used as part of intelligent remote I/O with an Allen-Bradley Logix PLC system. HDD modules require a SNAP PAC R-series controller or a SNAP PAC brain for I/O processing.
This data sheet covers the following modules:
The data sheet also covers the following accessories used with SNAP HDD modules:
SNAP High-Density Digital Module User's Guide
This guide covers how to install and test SNAP 16-channel and 32-channel digital modules, part of the SNAP PAC System. These modules provide 16 or 32 points of digital input or digital output in the same space as a 4-channel digital module. They are ideal for OEMs and for anyone who needs up to 512 digital points on a single mounting rack. SNAP high-density digital modules include the following part numbers:
  • SNAP-IAC-16
  • SNAP-IAC-A-16
  • SNAP-IAC-K-16
  • SNAP-IDC-16
  • SNAP-IDC-32
  • SNAP-IDC-32D
  • SNAP-IDC-32DN
  • SNAP-IDC-32-FM [OBSOLETE]
  • SNAP-IDC-32N
  • SNAP-ODC-32-SNK
  • SNAP-ODC-32-SNK-FM  [OBSOLETE]
  • SNAP-ODC-32-SRC
  • SNAP-ODC-32-SRC-FM  [OBSOLETE]
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
