SNAP-IDC5-FAST
SNAP-IDC5-FAST
$71.75 (USA and Canada only)
SNAP 4-Ch High-Speed 2.5 - 16VDC Digital (Discrete) Input Module
The SNAP-IDC5-FAST provides four channels of high-speed 2.5-16 VDC digital input. Each channel senses the on/off status for DC voltages from sources such as proximity switches, push buttons, or auxiliary contacts. The module has removable top-mounted connectors for easy access to field wiring, as well as channel-specific LEDs for convenient troubleshooting.
SNAP-IDC5FAST*
SNAP-IDC5-FAST-A**
SNAP-IDC5MA
Key Feature
High-speed
High-speed
Diagnostic switches
Wire size
22 to 14 AWG
22 to 14 AWG
22 to 14 AWG
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Nominal Input Voltage
5 VDC
28 VDC
24 VAC/VDC
Channel-to-channel isola­tion
300 VAC
(1,500 V transient)
300 VAC
(1,500 V transient)
300 VAC
(1,500 V transient)
Input Voltage Range
2.5–16 VDC
18–32 VDC
10–32 VAC/VDC
Turn-on Voltage
2.5 VDC
18 VDC
10 VAC/VDC
Turn-off Voltage
1 VDC
5 VDC
3 VAC/VDC
Input Resistance
440 ohms (nominal)
8 K ohms (nominal)
15 K ohms (nominal)
Logic Side Ratings
Logic Output Voltage
<0.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 0.4 mA sourcing
<0.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 0.4 mA sourcing
<0.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 400 mA sourcing
Logic Supply Voltage***
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
Logic Supply Current
50 mA maximum
50 mA maximum
50 mA maximum
Negative True Logic
Output Drive
TTL 74 Series = 1 UL
TTL 74LS Series = 5 UL
Module Ratings
Number of Channels Per Module
4
4
4
Turn-on Time
0.025 msec*
0.025 msec**
5 msec
Turn-off Time
0.025 msec*
0.025 msec**
15 msec
Optical Isolation
(Field Side to Logic Side)
4,000 volts (transient)
Temperature
-20 °C to 70 °C, operating
-40 °C to 85 °C, storage
UL, CE, ATEX, CSA, RoHS, DFARS; UKCA
UL, CE, CSA, RoHS, DFARS; UKCA
CE, RoHS, DFARS; UKCA
Lifetime
Lifetime
30 months
* At 20kHz, 5Vp-p square wave input, 50% duty cycle.
** At 20kHz, 28Vp-p square wave input, 50% duty cycle.
*** When used with an I/O processor (brain or on-the-rack controller), the processor requires 5.0 to 5.2 VDC.
SNAP PAC System Product Guide
SNAP Digital Input Modules Data Sheet
SNAP digital input modules are designed to work with SNAP PAC racks and can sense either AC or DC signals.
All SNAP digital input modules are compatible with SNAP PAC brains and R-series controllers, including Wired+Wireless models.
Most digital input modules are also compatible with SNAP D-series or legacy M-series and B-series racks and with the brains that mount on them.
This data sheet applies to:
CE Declaration of Conformity: ATEX
RPM Measurement Techniques
This technical note discusses field devices and methods for measuring the rotational speed of a shaft in revolutions per minute (RPM). RPM measurement is important when controlling or monitoring the speed of motors, conveyors, turbines, etc.
CAD 3D Drawing: SNAP-IDC5-FAST Digital Input Module
This CAD file contains a 3-dimensional drawing of the SNAP-IDC5-FAST digital input module, which provides four channels of high-speed 2.5-16 VDC digital input.
CAD Drawing: SNAP I/O Module
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
