SNAP-ODC-32-SNK-FM
SNAP-ODC-32-SNK-FM
OBSOLETE SNAP 32-channel Digital (Discrete) Output Module, 5-60 VDC Load Sinking
Please consider SNAP-ODC-32-SNK ​or contact Opto 22 Pre-Sales engineers for more information.
The SNAP-ODC-32-SNK-FM digital output module (load sinking) provides 32 digital output channels in one compact SNAP module. This module is ideal for OEMs and others with applications with high point counts, or for those requiring a large number of digital output channels on one SNAP I/O rack. The high-density configuration reduces per-point costs of digital I/O systems by providing up to eight times as many I/O channels in the same space.
If you're unsure whether you need a sinking or sourcing module, see the sinking/sourcing demo or watch the brief Sinking vs. Sourcing video.
For easy field wiring, use the SNAP-ODC-HDB-FM breakout rack and the SNAP-HD-BF6 header cable. A wiring harness with flying leads (SNAP-HD-CBF6) is also available.
Reference Charts: Build your system in the SNAP I/O Configurator.
SNAP-ODC-32-SRC
SNAP-ODC-32-SRC-FM [Obsolete]
SNAP-ODC-32-SNK
SNAP-ODC-32-SNK-FM [Obsolete]
Switching Voltage
5–60 VDC
5–60 VDC
Nominal Switching Voltage
12–24 VDC
12–24 VDC
Logic Voltage and Current
5 VDC ± 0.1 @ 150 mA
Maximum Off State Voltage
60 VDC
60 VDC
Output Leakage, Typical
<10 microamps per channel (60 V, 70 °C)
Maximum Load per Point
0.25 A
0.25 A
Voltage Drop
0.15 VDC @ 0.25 A
0.15 VDC @ 0.25 A
Surge (1 sec.)
1 A
1 A
Output Arrangement
32 output channels; 4 groups of 8 outputs each. Points in each group share a common positive connection.
32 output channels; 4 groups of 8 outputs each. Points in each group share a common negative connection.
Maximum Operating
Common Mode Voltage
250 V
250 V
Isolation: Field to Logic
1500 V
1500 V
Output Turn-On/Off Time
100 microseconds
100 microseconds
Polling time from I/O proces­sor to module1
2–30 ms typical2
2–30 ms typical2
Indicators
None; use optional OptoTerminal-G20 diag­nostic display or breakout rack.
None; use optional OptoTerminal-G20 diagnostic display or breakout rack.
Maximum Number of HDD Modules on One Mounting Rack
16
16
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Operating Temperature
-20 to 70 °C
-20 to 70 °C
Storage Temperature
-40 to 85 °C
-40 to 85 °C
CE, RoHS, DFARS; UKCA
UL, CE, RoHS, DFARS; UKCA
Lifetime
Lifetime
1 Affects turn-on and turn-off determination
2 Time varies based on the SNAP PAC I/O processor (brain or on-the-rack controller), processor configuration, and Ethernet host communication activity.
Comparison Chart: SNAP 4-Channel and High-Density Digital Modules
This document compares 4-channel and high-density SNAP digital I/O modules.
Sinking or Sourcing Technical Note
Are you confused about sinking and sourcing when wiring DC circuits? This technical note explains what sinking and sourcing mean, explores where you would use one wiring method rather than the other, and shows how to use a digital output module with your DC circuit.
Using ioDisplay 6.0 with SNAP High-Density Digital Modules Technical Note
This technical note is for customers using SNAP high-density digital modules with ioControl 6.1 and ioDisplay 6.0.
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
Sinking vs Sourcing
Switching a DC circuit? Learn about sinking and sourcing, and the digital output modules to use with each.
