SNAP-ODC5ASNK
SNAP-ODC5ASNK
$96.75 (USA and Canada only)
SNAP 4-Ch 5-200 VDC Digital (Discrete) Output Module, Load Sinking
The SNAP-ODC5ASNK provides four channels of 5-200 VDC digital output in a sink configuration, each channel switching a separate DC load. The module features a removable top-mounted connector for easy access to field wiring and channel-specific LEDs for troubleshooting.
If you're unsure whether you need a sinking or sourcing module, see the sinking/sourcing demo or watch the brief Sinking vs. Sourcing video.
SNAP-ODC5MA
SNAP-ODC5-i
SNAP-ODC5A-i
SNAP-ODC5ASNK
Key Feature
Diagnostic switches
Four isolated channels
Load sinking
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Line Voltage - Range
5–60 VDC
5–60 VDC
5–200 VDC
5–200 VDC
Line Voltage - Nominal
5–48 VDC
5–48 VDC
5–200 VDC
5–200 VDC
Current Rating
0 °C to 70 °C Ambient
2 amps per module
0.5 amps per channel
3 amps per module
3 amps per module
3 amps per module
Surge Current
1.5 amps peak for
1 second
5 amps peak for
1 second
5 amps peak for
1 second
5 amps peak for
1 second
Minimum Load
20 mA
20 mA
20 mA
20 mA
Output Voltage Drop
1.6 volts max.@ 0.75 amps
Off-state Leakage
1 mA @ 60 VDC
1 mA @ 60 VDC
1 mA @ 200 VDC
1 mA @ 200 VDC
Peak Blocking Voltage
60 VDC
60 VDC
200 VDC
200 VDC
Fuse
(Common to all Channels)
Has four isolated
channels. User must provide own fusing.
Has four isolated
Has four isolated
250 VAC - 4A 5x20 mm
Fast-acting Bell Fuse Part: BEL 5HF4
Opto 22 Part: SNAP-FUSE4AB
Channel-to-channel
isolation
300 VAC
(1500 V transient)
300 VAC
(1500 V transient)
300 VAC
(1500 V transient)
Not applicable
Logic Side Ratings
Pickup Voltage
4 V @ 5.5 mA
4 V @ 5.5 mA
4 V @ 5.5 mA
4 V @ 5.5 mA
Dropout Voltage
1 VDC
1 VDC
1 VDC
1 VDC
Control Resistance
220 ohms
220 ohms
220 ohms
220 ohms
Logic Supply Voltage
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
Logic Supply Current
50 mA maximum
50 mA maximum
50 mA maximum
50 mA maximum
Module Ratings
Number of Channels Per Module
4
4
4
4
Turn-on Time
100 usec
100 usec
100 usec
100 usec
Turn-off Time
750 usec
750 usec
750 usec
750 usec
Isolation (Field Side to Logic Side)
4,000 volts (transient)
Temperature
-20 ° to 70 °C, operating
-40 ° to 85 °C, storage
Wire size range
22 to 14 AWG
22 to 14 AWG
22 to 14 AWG
22 to 14 AWG
UL, CE, RoHS, DFARS; UKCA
30 months
Lifetime
Lifetime
Lifetime
SNAP PAC System Product Guide
SNAP Digital Output Modules Data Sheet
Opto 22 SNAP digital output modules are designed to mount on SNAP PAC racks and be used with SNAP PAC brains and R-series controllers, both standard wired and Wired+Wireless models. You can choose from AC or DC output modules.
These modules are also compatible with SNAP D-series and legacy M-series and B-series racks, and they can be used with legacy Ethernet-based brains as well as other SNAP brains, such as the serial B3000 or the B3000-HA.
SNAP-OAC5
SNAP-OAC5-I
SNAP-OAC5MA
SNAP-ODC5A-I
SNAP-ODC5ASNK
SNAP-ODC5-I
SNAP-ODC5MA
SNAP-ODC5SNK
SNAP-ODC5SRC
Sinking or Sourcing Technical Note
Are you confused about sinking and sourcing when wiring DC circuits? This technical note explains what sinking and sourcing mean, explores where you would use one wiring method rather than the other, and shows how to use a digital output module with your DC circuit.
CAD Drawing: SNAP I/O Module
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
Sinking vs Sourcing
Switching a DC circuit? Learn about sinking and sourcing, and the digital output modules to use with each.
