SNAP-ODC5MA
SNAP-ODC5MA
$157.00 (USA and Canada only)
SNAP 4-Ch Isolated 5-60 VDC Digital (Discrete) Output Module with Manual/Auto Switches
The SNAP-ODC5MA provides four isolated channels of 5-60 VDC digital output, each switching a separate DC load. The module features manual-on/manual-off/automatic switches that override output from the application and are ideal for testing field device wiring.
SNAP-ODC5MA
SNAP-ODC5-i
SNAP-ODC5A-i
SNAP-ODC5ASNK
Key Feature
Diagnostic switches
Four isolated channels
Load sinking
Torque, hold-down screws
Torque, connector screws
5.26 in-lb (0.6 N-m)
Line Voltage - Range
5–60 VDC
5–60 VDC
5–200 VDC
5–200 VDC
Line Voltage - Nominal
5–48 VDC
5–48 VDC
5–200 VDC
5–200 VDC
Current Rating
0 °C to 70 °C Ambient
2 amps per module
0.5 amps per channel
3 amps per module
3 amps per module
3 amps per module
Surge Current
1.5 amps peak for
1 second
5 amps peak for
1 second
5 amps peak for
1 second
5 amps peak for
1 second
Minimum Load
20 mA
20 mA
20 mA
20 mA
Output Voltage Drop
1.6 volts max.@ 0.75 amps
Off-state Leakage
1 mA @ 60 VDC
1 mA @ 60 VDC
1 mA @ 200 VDC
1 mA @ 200 VDC
Peak Blocking Voltage
60 VDC
60 VDC
200 VDC
200 VDC
Fuse
(Common to all Channels)
Has four isolated
channels. User must provide own fusing.
Has four isolated
Has four isolated
250 VAC - 4A 5x20 mm
Fast-acting Bell Fuse Part: BEL 5HF4
Opto 22 Part: SNAP-FUSE4AB
Channel-to-channel
isolation
300 VAC
(1500 V transient)
300 VAC
(1500 V transient)
300 VAC
(1500 V transient)
Not applicable
Logic Side Ratings
Pickup Voltage
4 V @ 5.5 mA
4 V @ 5.5 mA
4 V @ 5.5 mA
4 V @ 5.5 mA
Dropout Voltage
1 VDC
1 VDC
1 VDC
1 VDC
Control Resistance
220 ohms
220 ohms
220 ohms
220 ohms
Logic Supply Voltage
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
Logic Supply Current
50 mA maximum
50 mA maximum
50 mA maximum
50 mA maximum
Module Ratings
Number of Channels Per Module
4
4
4
4
Turn-on Time
100 usec
100 usec
100 usec
100 usec
Turn-off Time
750 usec
750 usec
750 usec
750 usec
Isolation (Field Side to Logic Side)
4,000 volts (transient)
Temperature
-20 ° to 70 °C, operating
-40 ° to 85 °C, storage
Wire size range
22 to 14 AWG
22 to 14 AWG
22 to 14 AWG
22 to 14 AWG
UL, CE, RoHS, DFARS; UKCA
30 months
Lifetime
Lifetime
Lifetime
SNAP PAC System Product Guide
SNAP Digital Output Modules Data Sheet
Opto 22 SNAP digital output modules are designed to mount on SNAP PAC racks and be used with SNAP PAC brains and R-series controllers, both standard wired and Wired+Wireless models. You can choose from AC or DC output modules.
These modules are also compatible with SNAP D-series and legacy M-series and B-series racks, and they can be used with legacy Ethernet-based brains as well as other SNAP brains, such as the serial B3000 or the B3000-HA.
SNAP-OAC5
SNAP-OAC5-I
SNAP-OAC5MA
SNAP-ODC5A-I
SNAP-ODC5ASNK
SNAP-ODC5-I
SNAP-ODC5MA
SNAP-ODC5SNK
SNAP-ODC5SRC
Case Study: AAQUA NV
Antwerp-based AAQUA NV has specialized in engineering and constructing industrial wastewater treatment plants since 1999, with customers all over the world. Where possible, the company also adds value to customer waste, either by recycling wastewater to drinking water quality or by capturing the energy in the water to reduce fuel costs.
Initially AAQUA often worked with a subcontractor to automate treatment, but in 2005 they began offering automation themselves. To do so, the small company needed an automation system that was Ethernet based, flexible, reliable, offered remote access, and was easy to learn.
In this case study, read how they found that system and how they use it today.
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
