SNAP-ODC5SNKFM
SNAP-ODC5SNKFM
OBSOLETE  SNAP 4-Ch 5-60 VDC Digital (Discrete) Output Module, Load Sinking
Please contact Opto 22 Pre-Sales engineers for more information or see Form 2411, Obsolete SNAP 4-Channel Digital I/O Technical Note.
The SNAP-ODC5SNKFM provides four channels of 5-60 VDC digital output in a sink configuration, each channel switching a separate DC load. The module includes a guard.
If you're unsure whether you need a sinking or sourcing module, see the sinking/sourcing demo or watch the brief Sinking vs. Sourcing video.
SNAP-ODC5SRCFM
[Obsolete]
SNAP-ODC5SNKFM
[Obsolete]
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Line Voltage - Range
5–60 VDC
5–60 VDC
Line Voltage - Nominal
5–48 VDC
5–48 VDC
Current Rating 0°C to 70°C Ambient
3 amps per module
3 amps per module
Surge Current
5 amps peak for
1 second
5 amps peak for
1 second
Minimum Load
20 mA
20 mA
Output Voltage Drop
1.6 volts max.@ 0.75 amps
Off-state Leakage
1 mA @ 60 VDC
1 mA @ 60 VDC
Peak Blocking Voltage
60 VDC
60 VDC
Fuse
(Common to all Channels)
250 VAC - 4A 5x20 mm
Fast-acting Bell Fuse Part No. BEL 5HF4
Opto 22 Part SNAP-FUSE4AB
Logic Side Ratings
Pickup Voltage
4 V @ 5.5 mA
4 V @ 5.5 mA
Dropout Voltage
1 VDC
1 VDC
Control Resistance
220 ohms
220 ohms
Logic Supply Voltage
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
Logic Supply Current
50 mA maximum
50 mA maximum
Module Ratings
Number of Channels Per Module
4
4
Turn-on Time
100 usec
100 usec
Turn-off Time
750 usec
750 usec
Isolation (Field Side to Logic Side)
4,000 volts (transient)
Temperature
-20 to 70 °C, operating
-40 to 85 °C, storage
Wire size range
22 to 14 AWG
22 to 14 AWG
CE, CSA, RoHS, DFARS; UKCA
Lifetime
Lifetime
This technical note contains information you may need about OBSOLETE SNAP 4-Channel Digital I/O modules you’re still using. Included are part numbers, descriptions, specifications, wiring diagrams, and dimensional drawings. These parts have been removed from data sheets because we no longer sell them.
This document includes information on the following obsolete types of SNAP 4-channel digital I/O modules:
Sinking or Sourcing Technical Note
Are you confused about sinking and sourcing when wiring DC circuits? This technical note explains what sinking and sourcing mean, explores where you would use one wiring method rather than the other, and shows how to use a digital output module with your DC circuit.
CAD Drawing: SNAP I/O Module
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
Sinking vs Sourcing
Switching a DC circuit? Learn about sinking and sourcing, and the digital output modules to use with each.
