SNAP-PAC-R1-FM
SNAP-PAC-R1-FM
OBSOLETE SNAP PAC R-series Programmable Automation Controller - On-the-rack - REST API - Analog, full digital, serial
Please consider SNAP-PAC-R1​ or contact Opto 22 Pre-Sales engineers for more information.
Now developer and IoT ready with a built-in HTTP/HTTPS server and RESTful API. See Programming and Protocols, below.
** Compatible with groov EPIC. You can control SNAP PAC R-series I/O units with groov EPIC or control groov EPIC I/O units with a SNAP PAC R-series controller running PAC Control R10.a or higher. **
The SNAP-PAC-R1-FM programmable automation controller provides control, communication, and I/O processing in a compact, rack-mounted package. One of four components of the SNAP PAC System, the SNAP-PAC-R1-FM is fully integrated with PAC Project software, SNAP PAC brains, and SNAP I/O modules.
Used with the included PAC Project Basic software suite (or PAC Project Professional, purchased separately), the Ethernet-based SNAP-PAC-R1-FM can handle almost all your industrial control, remote monitoring, and data acquisition needs.
System Architecture
This intelligent, flexible PAC can be used in several ways. The SNAP-PAC-R1-FM can provide complete cell control on its own rack with I/O modules. It can also control SNAP PAC and groov EPIC I/O units at the same time for a larger system. Or the R1 can be used in a more extensive distributed control system as an I/O unit controlled by a groov EPIC processor or a SNAP PAC S-series controller. It can even be used as intelligent remote I/O for Allen-Bradley Logix PLC systems, such as ControlLogix and MicroLogix.
Networking
Two independent, 10/100 Mbps Ethernet network interfaces are included on each SNAP-PAC-R1. These interfaces have separate IP addresses and can be used to segment the control network from the company network or to provide Ethernet link redundancy in case of link failure or maintenance. In addition, the controller has an RS-232 serial port with hardware handshaking, which can be used for PPP (Point-to-Point Protocol) communication over a modem or for direct connection to serial devices.
The SNAP-PAC-R1-FM is programmed using the included PAC Control software. PAC Control is a flowchart-based tool for developing control applications, or strategies. You create and debug the strategy on your computer and then download it to the R1, where it runs independently. The controller has 16 MB of RAM and can run up to 16 PAC Control flowcharts at once (many more can be included in the strategy).
REST API: All I/O point and strategy variable data is available for secure access using the built-in HTTPS server and RESTful API, with data delivered in JSON format. For complete API documentation and steps for getting started, see developer.opto22.com. In addition, two Node-RED nodes are available. Note that minimum firmware R9.5a and PAC Project R9.5a are required to use the REST API.
You can build full-featured operator interfaces (HMIs) using the included PAC Display software, which taps the same tagname database you've already developed in PAC Control. SNAP PAC R-series controllers are also compatible with Opto 22's groov products and groov View HMI tool.
In addition to control, the SNAP-PAC-R1-FM provides communication. Because it is based on the Internet Protocol (IP), the SNAP-PAC-R1-FM can communicate simultaneously using several different protocols, including TCP/IP, PPP, Modbus/TCP, SNMP for network management, SMTP for emailing, and OptoMMP, the open memory-mapped protocol used by all Opto 22 Ethernet-based devices.
I/O Processing
The controller mounts on a SNAP PAC mounting rack with up to 4, 8, 12, or 16 digital, analog, serial, and special-purpose I/O modules. Choose the modules needed for your application from the extensive line of SNAP I/O modules.
  • Analog features include thermocouple linearization, minimum/maximum values, offset and gain calibration, scaling, ramping, TPO, output clamping, filter weight, and watchdog timer. The SNAP-PAC-R1-FM also offers up to 96 PID loops.
  • Digital features on 4-channel digital modules include latching, high-speed counting (up to 20 kHz depending on the module), quadrature counting, pulse generation and measurement, TPO, and watchdog timer. Features on high-density digital modules are more limited (see module data sheet for details).
Compare SNAP PAC controllers and brains.
Processor
200 MHz 32-bit ColdFire® 5475 with integrated floating-point unit (FPU)
Memory
  Total RAM
  Battery-backed RAM
  Flash
16 MB (5 MB available for PAC Control strategy and 2 MB for file storage)
  2 MB (1 MB available for PAC Control strategy)
  8 MB (3.25 MB available for PAC Control strategy; 384 KB available for file storage)
Removable storage
(Models with manufacture dates of November 2008 and newer. Requires firmware R9.4a or higher and loader R6.1a or higher) MicroSD card slot: supports microSD or microSDHC cards to 32 GB.
(Note: Models with card slots and firmware R8.4 through R9.3e support microSD cards up to 2 GB only.)
Backup battery
Rechargeable (recharges whenever the brain has power), 3-year power-off data retention (replacement part number: SNAP-PAC-BATTERY-ML2430)1
Communication
  Ethernet
  RS-232 serial
Two independent 10/100 Mbps Ethernet network interfaces (RJ-45 connectors). Each interface has a separate IP address. Connects to host and I/O. Supports Auto MDI-X (crossover cable not needed).
One RS-232 serial port2 with hardware handshaking. Connects to host (via modem and PPP) or serial device. Cannot connect to serial I/O.
I/O unit compatibility
SNAP PAC I/O units: SNAP PAC R-series and EB-series I/O units
groov EPIC
groov RIO
Power requirements
5.0–5.2 VDC @ 1.5 A
Hold-down screw
Torque: Not to exceed 1 in-lb (0.11 N-m)
Connector screw
Torque: 1.7 in-lb (0.19 N-m)
Environmental
  Operating temperature
  Storage temperature
  Humidity
-20 °C to 60 °C
-40 °C to 85 °C
0% to 95% relative humidity, non-condensing
Software
  PAC Project Basic
  REST API3
Includes programming, HMI software, and configuration software; included with purchase of controller.
PAC Project Basic plus OPC 2.0-compliant OPC server, database connectivity, OptoControl strategy and OptoDisplay project importing, and support for Ethernet link redundancy or network segmenting.
Use HTTPS to access data (read/write or read-only) from controller tags using your chosen programming language. Data returned in JSON. More information at developer.opto22.com
Number of charts that can run simultaneously
16
Agency certifications
ATEX, DFARS, CE, RoHS; UKCA
Other features
• Multiple protocol support including TCP/IP, FTP, EtherNet/IP, Modbus/TCP,
  SNMP v2.0c, OptoMMP™, and SMTP
• Built-in I/O processor handles up to 16 digital
4, analog, and serial I/O modules   on the same rack
• Real-time clock
• FTP server/client with file system (in RAM and in removable storage)
• Scratch Pad area for peer-to-peer communication
• Configurable link redundancy or segmented networking
  for I/O-controller subnetting (when using PAC Project Professional)
1 Models manufactured before July 1, 2007 have a user-replaceable 3-volt CR2032 Lithium battery (typical service life with power off: 5 years).
2 Connecting to a serial device requires configuration in PAC Manager; PAC Control handles communication.
3 Requires firmware R9.5a or higher
4 SNAP-PAC-R1s with serial numbers lower than 600,000, and all SNAP-PAC-R1-Bs, are limited to eight 4-channel digital modules per rack; remaining eight can be analog, serial, and high-density digital modules.
Using Modbus Devices with Opto 22 Products Technical Note
This technical note introduces the Modbus protocol and gives you basic information for using it to communicate between Opto 22 products and other devices. Because Modbus/TCP and Modbus serial are handled differently by various manufacturers, the tech note describes specific areas that may be a concern and includes troubleshooting suggestions.
This README file lists revision changes made to the firmware used in SNAP PAC S-series, R-series, and SoftPAC controllers; SNAP PAC EB-series and SB-series brains; and G4EB2 and G4D32EB2 brains.
PAC Project Readme Notes
Latest Readme for PAC Project Basic and Professional. Includes information on new features, enhancements, and bug fixes for each PAC Project application: PAC Control, PAC Display, OptoOPCServer, PAC Manager, and Tools.
SNAP PAC I/O Coprocessor Firmware README
This README file lists changes to the I/O coprocessor firmware available in rack-mounted Opto 22 controllers and brains manufactured starting in 2016.
I/O coprocessors can be present in the SNAP PAC R-series controllers, and in SNAP PAC EB-series and SB-series brains. Instructions to find out if your device has an I/O coprocessor are included in this README and in the PAC Manager User's Guide.
NOTE: The following products manufactured with I/O coprocessors have firmware R3.0a; you do not need to update the firmware in these products at this time:
  • SNAP-PAC-EB1
  • SNAP-PAC-EB1-W
  • SNAP-PAC-SB1
  • SNAP-PAC-SB2
SNAP Legacy Firmware README
This README file lists revision changes made to the firmware used in SNAP PAC family controllers before Version 8.0a, the SNAP-LCE controller, and SNAP Ultimate, Ethernet, and Simple brains.
EtherNet/IP Configurator 3.0 Release Notes
This document contains the release notes for version 3.0 of the EtherNet/IP Configurator.
Guide to Networking SNAP PAC Products
Networking can be a complex subject. This guide tries to reduce the complexity by providing guidelines for how you might set up communications between your computer or mobile device and your SNAP PAC control system.
The goal is for you to be able to monitor and control your system from anywhere you need to, either inside your facility or outside it. It's possible to do this because Opto 22 control systems are built on standard protocols such as TCP and UDP over IP, which are the same protocols used by off-the-shelf computers, routers, and the internet.
This guide shows you how to communicate with Opto 22’s SNAP PAC controllers using wired Ethernet networks and wireless LANs, both within your facility and over the internet.
EtherNet/IP for SNAP PAC Protocol Guide
This guide provides detailed descriptions of the EtherNet/IP commands that can be accessed when using remote Opto 22 I/O with an Allen-Bradley controller.
Using IEEE Floats in Opto 22 Products
While computers, CPUs, and electronic devices store numbers in binary format, most often they represent real numbers as floating point numbers, or floats. For example, in industrial automation applications, all analog values read from an I/O unit are floats.
This document describes how the IEEE 754 standard for floats is used in Opto 22 products, including groov RIO, groov EPIC, and SNAP PAC systems.
Configuring Email Applications for Opto 22 Products
You can use many Opto 22 products to send email notifications to keep engineers and technicians aware of
important conditions in your system. For example:
  • You can send email through a PAC Control strategy running on a groov EPIC or SNAP PAC controller.
  • Your groov View HMI can send event notifications via email.
  • Your Node-RED flow on groov RIO or groov EPIC can send email.
IMPORTANT: Due to security changes, you will stop receiving emails from your Opto 22 devices unless you
configure your email account with a new application-specific password. This technical note gives you details and steps to configure your account.
Opto 22 announces strategic partnership with IBM and acceptance into the IBM Watson IoT partner ecosystem
Opto 22 announces strategic partnership with IBM and acceptance into the IBM Watson IoT partner ecosystem, providing developers a full stack end-to-end toolset for rapidly developing and deploying industrial IoT applications.
This partnershiip will bridge the gap between existing industrial assets and infrastructure, and the digital world of mobile, cloud, and information technology.
Watch this video and see how to get started.
Connect Real-world Data to an AT&T M2X Device Technical Note
This technical note shows you how to send real-world data, in this example a temperature in degrees F, to an AT&T M2X device in the cloud.
2017 White Paper: State of the IIoT, 2017
The next industrial revolution, the Industrial Internet of Things (IIoT), is happening now. This white paper summarizes the key IIoT trends from 2016, with predictions and recommendations for 2017 on:
- IIoT challenges still to be met
- Standards and architectures that work well for the IIoT
- Platforms to watch; their strengths and weaknesses
Case Study: Hashemite University Solar
The country of Jordan, with few oil resources, imports 96% of its energy needs from neighboring Middle Eastern countries. Starting in 2007, the Jordanian government committed to investing heavily in renewable and nuclear energy.
One of the universities leading the adoption of renewable energy technology is Hashemite University (HU) in Zarqa. This case study shows how FB Group in Amman designed and built a solar farm with enough photovoltaic (PV) capacity to power the entire university.
Connect Industrial Devices to IBM Watson IoT Technical Note
If you've heard about our Opto 22 SNAP PACs with their built-in RESTful API (application program interface), you may be wondering how you'd use that API to send real-world data to the IBM® Watson IoT® platform.
This technical note shows you how, step by step. This technical note is also a blog post on our website.
For more information, see Press Release 2217.
Case Study: Toyo Tanso USA
Toyo Tanso USA manufactures a fine grade of graphite called isotropic graphite, and the company also provides graphite-related silicon carbide surface treatments to customers.
The batch automation process systems used to perform these surface treatments are in a busy, tough industrial setting. The multiple vessels involved in the process each require different specializations and careful management.
To control the vessels, Toyo Tanso needed a rugged control system with plenty of I/O options—and one that could be easily programmed and deployed.
Opto 22 Conecta Digitalmente el IIoT con el Lanzamiento de Nodos de Node-RED para los PAC Industriales
PARA PUBLICACIÓN INMEDIATA: Opto 22 Conecta Digitalmente el IIoT con el Lanzamiento de Nodos de Node-RED para los PAC Industriales
Opto 22 Digitally Wires the IIoT with Release of Node-RED Nodes for Industrial PACs
Opto 22 Digitally Wires the IIoT with Release of Node-RED Nodes for Industrial PACs.
Opto 22 announces immediate availability of Node-RED nodes for its industrial programmable automation controllers (PACs), significantly decreasing Industrial Internet of Things (IIoT) application development time and complexity.
Opto 22 Permite Desarrollo Rápido de Aplicaciones Industriales para la Internet de las Cosas con el Lanzamiento de la API REST para Controladores Programables de Automatización (PACs) In
PARA PUBLICACIÓN INMEDIATA: Opto 22 Permite Desarrollo Rápido de Aplicaciones Industriales para la Internet de las Cosas con el Lanzamiento de la API REST para Controladores Programables de Automatización (PACs) In
Opto 22 Enables Rapid Industrial Internet of Things Application Development With Release of RESTful API to Industrial Programmable Automation Controllers (PACs)
Press release announcing new built-in HTTP/HTTPS server and RESTful API in Opto 22 SNAP PAC standalone and rack-mounted programmable automation controllers.
For complete API documentation and steps to get started, visit developer.opto22.com.
La API de SNAP PAC REST y la Internet de las Cosas para los Profesionales del OT
La API de SNAP PAC REST y la Internet de las Cosas para los Profesionales del OT, SNAP PAC REST API OT Technical Note (Spanish)
SNAP PAC REST API and the Internet of Things - for OT Professionals
We’ve all heard about the Internet of Things (IoT) and its promises: bringing useful data directly to people who make business decisions, and enabling machines to communicate with each other and make decisions for human benefit.
But how does the IoT actually work? How does the data get from inside these physical "things" to computer networks where it can be used?
This technical paper describes that pathway for OT (operational technology) professionals—automation professionals. It describes the kinds of data you may be asked to provide and why. It explains how data from physical "things"—especially existing sensors and actuators that have no IoT capabilities built in—can be securely communicated to company computer networks, without disturbing control networks.
The paper also explains concepts important to any IoT strategy, like encryption and authentication, and introduces a new method to achieve the IoT results you need now, without requiring a complex chain of conversion hardware and software.
Learn about the REST API and the IoT from an information technology (IT) professional's standpoint in the companion tech note, SNAP PAC REST API and the Internet of Things - for IT Professionals.
La API de SNAP PAC REST y la Internet de las Cosas para los Profesionales de IT
La API de SNAP PAC REST y la Internet de las Cosas para los Profesionales de IT - SNAP PAC REST API IT Technical Note (Spanish)
But how does the IoT actually work? How does the data get from inside these machines to computer networks where we can use it?
This technical paper describes that pathway for IT (information technology) professionals, explaining how physical "things" communicate, what kinds of data in them might be useful, and the current barriers to getting that data—especially from existing sensors and devices that have no IoT capabilities built in.
The paper also describes a new method to cut through those barriers and achieve the IoT results you want now.
Learn about the REST API and the IoT from an automation professional's standpoint in the companion tech note, SNAP PAC REST API and the Internet of Things - for OT Professionals.
Tutorial de Computacion en el Borde
2184S Tutorial de Computacion en el Borde (Spanish Edge Computing Primer - Spanish)
CE Declaration of Conformity: ATEX
Su Tutorial de la IoT: Reduciendo la brecha entre OT y IT
Your IoT Primer: Bridge the Gap between OT and IT
You've probably heard about the Internet of Things (IoT). But what is it, and how will it affect our businesses?
This primer helps you understand the IoT and the significant challenges we face to realize its benefits.
The primer defines operational technology (OT) and information technology (IT), and shows how they are converging and why. It defines IoT technologies and suggests 3 steps you can take to develop an effective and profitable IoT strategy.
Opto 22 Integrates Custom Applications with SNAP PAC Control Systems
Press release: Opto 22 Integrates Custom Applications with SNAP PAC Control Systems with Opto 22 .NET Controller Software Development Kit (SDK) for SNAP PAC.
Using microSD with Older Controller Firmware Technical Note
SNAP PAC controllers manufactured in November 2008 and later have a microSD card slot in the top of the controller’s case.
Behavior for the microSD card has changed since the first release. This technical note describes behavior with controller firmware versions older than 9.0.
If you are running controller firmware 9.0 or newer, use instructions in the controller user’s guide; do not use this technical note.
Quick Guide: Troubleshooting Info from SNAP PAC Systems
This technical note provides a quick guide about diagnostic files to collect and send in to Opto 22 Product Support for analysis when troubleshooting a SNAP PAC System.
Communication Tools & Protocols for Opto 22 Products Technical Note
This technical note describes the networking tools and protocols that are compatible with Opto 22 products for communication with a wide variety of software and systems.
Updating the Loader on a SNAP Device
It is rarely necessary to update the loader in a SNAP PAC controller or brain, but if you need to, this document shows you how. If you have questions, contact Opto 22 Product Support.
EtherNet/IP Implementation in SNAP PAC Products
This technical note summarizes EtherNet/IP technology and how SNAP PAC devices can be integrated into an EtherNet/IP environment to send data to EtherNet/IP enabled devices such as Allen-Bradley PLCs.
Software for Programmable Automation Controllers (Chinese)
This white paper explores some important features of programming software for a programmable automation controller (PAC).
For additional white papers on PACs, see About PACs.
Considerations for Choosing a Programmable Automation Controller (PAC)
This white paper compares programmable automation controllers (PACs) with other automation technologies and suggests several considerations to keep in mind when choosing PACs for your industrial control or monitoring application.
6 Razones Para Considerar el Sistema SNAP PAC
Este documento corto sugiere seis razones porqué debe de considerar el Sistema SNAP PAC para su siguiente proyecto de automatización.
6 Reasons to Consider the SNAP PAC System for Your Next Project
This short document suggests six reasons why you should consider the SNAP PAC System for your next automation project.
Caso: Henkel Capital México (Spanish)
Caso sobre la automización de una empresa de adhesivos en la ciudad de Salamanca, Guanajuato, México. (Case study of how an adhesives manufacturer in Salamanca, Guanajuato, México, was automated.)
SNAP PAC Memory Usage Technical Note
This technical note shows how SNAP PAC memory, both volatile and non-volatile, is used. It compares memory available in the standalone SNAP PAC S-series, on-the-rack SNAP PAC R-series, and software-based SoftPAC controllers, and it also shows differences between wired Ethernet PACs and Wired+Wireless™ PACs.
Understanding Programmable Automation Controllers (PACs) in Industrial Automation (Chinese)
NOTE: This document is written in Chinese.
This white paper describes the advent of the programmable automation controller (PAC) and its use in modern industrial applications.
For additional white papers on PACs, see the Guide to PACs.
Technical Note: Using Offset and Gain
This technical note shows you how to set offset and gain for Opto 22 analog input modules.
SNAP PAC I/O Coprocessor Firmware (Single Download)
I/O coprocessor firmware for rack-mounted SNAP PAC controllers and brains (single download).
Not all rack-mounted Opto 22 products have an I/O coprocessor.
See the SNAP PAC I/O Coprocessor Firmware README for instructions to find out if your device has an I/O coprocessor.
This zip file contains a README file and updates (.bin files) for SNAP PAC products with an I/O coprocessor:
  • SNAP-PAC-R1, -R1-W, and R1-B controllers
  • SNAP-PAC-R2 and -R2-W controllers
  • SNAP-PAC-EB1 and -EB1-W brains
  • SNAP-PAC-EB2 and -EB2-W brains
  • SNAP-PAC-SB1 and -SB2 brains
You must download and unzip this file to access the specific firmware file for your Opto 22 controller or brain.
SNAP PAC R-Series Controller Bootloader
This download contains special firmware that upgrades the controller bootloader (or "loader") in SNAP PAC R-series controllers.
Starting in April 2018, some R1, R1-FM, R1-B, and R2-series controllers include a new flash component. These units have a hardware revision date of April 2, 2018 (or newer) and require bootloader R6.2c (or higher).
For details, see Opto 22 KB article KB87213.
Previous Loaders
See KB83929, Updating SNAP PAC Controllers to use microSDHC Cards on the Opto 22 website for important information on using the loader with SNAP PAC controllers.
SNAP-PAC-R1 Controller Firmware
This download contains current firmware for the SNAP-PAC-R1, SNAP-PAC-R1-B, and SNAP-PAC-R1-FM controllers. Current firmware for all SNAP PAC brains and controllers is available in a single download here.
NOTE: Opto 22 recommends that you always use the most recent release of PAC Manager. Depending on the shipment date or the version number of the firmware currently installed on your SNAP-PAC-R controller, older versions of PAC Manager cannot install certain levels of firmware:
  • As of February 22, 2022, some SNAP-PAC-R controllers ship with new Ethernet components, along with PAC Firmware R10.4d (or higher) and new bootloader firmware to support the new components. PAC Firmware R10.4d (or higher) will not permit installing firmware lower than R10.4d on these controllers. To update firmware on these controllers, you need PAC Manager R10.4b or higher, installed by one of these methods:
    • PAC Project 10.4002 or higher
    • Build 7 of the R10.4b PAC Manager installer (or higher), identifiable by the file name PAC_Manager_R10.4b-7.exe. If you are not sure that PAC Manager was installed by build 7 of the installer, you can find the installer version number by clicking Control Panel > Programs (or Programs and Features), then scrolling down the list of programs until you find “Opto22 PAC Manager”. Next to it, it should say “R10.4b build 7”.
  • Effective April 2, 2018, some SNAP PAC controllers and brains have new flash components. These units shipped with firmware R9.5g (or higher) and new bootloader firmware. PAC firmware versions R9.5f and lower are not compatible with the new component. If you inadvertently install firmware R9.5f or lower on one of these units, you can recover by using the Failsafe Bootloader Mode to install firmware R9.5g or higher.
    • For more information about the new flash component, see KB87213.
    • For details on Failsafe Bootloader Mode, see "Replacing Damaged Firmware" in the PAC Manager User's Guide (form 1704).
  • To install PAC firmware R9.2c or higher on the following controllers only, use PAC Manager R10.4b (or higher), installed by either PAC Project 10.4002 or build 7 of the PAC Manager R10.4b installer. Wireless versions are not affected by this issue:
    • SNAP-PAC-R1
    • SNAP-PAC-R1-FM
    • SNAP-PAC-R1-B
    • SNAP-PAC-R2
    • SNAP-PAC-R2-FM
See the README document for information on changes and fixes in the current version of this product's firmware.
Controller Time Synchronization Application
This software application updates the internal clock for an Ethernet-connected Opto 22 controller. The application runs in Windows at the command prompt, and can update controller clocks regularly or just once.
This application is used with the following Opto 22 controllers:
  • SNAP PAC S- and R-Series
  • Ultimate I/O (UIO)
  • SNAP-LCE
  • SNAP-LCM4
  • M4
  • M4RTU
  • M4IO
This download is freeware. Before downloading, read the Legal Agreement.
Security Certificates
Current security certificates are embedded in the firmware for Opto 22 products. If you are using recent firmware or can update your device to current firmware, you do not need any of these certificates. If you cannot update firmware, then you can apply a certificate from this zip file as needed.
This zip file contains the following certificates:
  • DigiCert High Assurance EV Root CA (DigiCert.der) - Valid from 11/9/2006 to 11/9/2031
  • GeoTrust Primary Certification Authority (GeoTrustPCS.crt) - Valid from 11/26/2006 to 7/16/2036
  • GlobalSign Root CA (GSR1.crt) - Valid from 9/1/1998 to 1/28/2028
  • GTS Root R1 (gtsr1.der) - Valid from 6/21/2016 to 6/21/2036
  • GTS Root R2 (gtsr2.der) - Valid from 6/21/2016 to 6/21/2036
Certificate installation instructions are located here: Background information
A valid security certificate may be required by mail servers to allow you to send emails from your Opto 22 products, for example, through:
  • a PAC Control strategy running on a groov EPIC or SNAP PAC controller
  • a groov View HMI sending event notifications
  • a Node-RED flow on groov RIO or groov EPIC
Valid security certificates may also be required by other services you may be using via software on your Opto 22 device (for example, using Node-RED to move data in and out of Google Sheets).
All providers of email or other services update their security certificates from time to time. When that happens, your email or other service will stop working until you either install a new certificate or update firmware that contains the new certificate. Make sure you set up error handling procedures or other ways to verify that services are working.
Opto 22 updates certificates as soon as we know about new ones. If you see a security error (for example, -2104 in PAC Control) or have some other indication of a certificate issue, be sure to check for new firmware or download this zip file. If you need help, contact Opto 22 Product Support.
SNAP PAC RESTful API to Access Database Example
This download is an interactive Access database sample that builds commands to read data from an Opto 22 SNAP PAC programmable automation controller and store the data in a Microsoft Access table.
The download includes all files needed and a technical note documenting the sample. Before you download, read the Legal Agreement.
Watch the video below for an introduction to the samples.
SNAP PAC RESTful API to Excel Spreadsheet Example
This download contains sample spreadsheets you can use to read from and write to an Opto 22 SNAP PAC programmable automation controller via the PAC’s RESTful API. In this way you can securely share I/O point and variable data in your SNAP PAC controller with an Excel spreadsheet.
The download includes all files needed and a technical note documenting the samples. Before you download, read the Legal Agreement.
Video: SNAP PAC RESTful API to MS Excel
Click here to download the Excel example
What does the new built-in RESTful API in Opto 22 SNAP PAC S-series and R-series programmable automation controllers mean to you? It means you can use a variety of programming languages to easily access data in the PAC.
Data includes I/O point information plus variables in your PAC Control strategy. Using the REST API and HTTPS server in the PAC, you can securely share data with a wide variety of software applications, devices, and online services.
Video: SNAP PAC RESTful API to MS Access
Click here to download the Access example.
Video: SNAP PAC R Series Controllers
A quick overview of SNAP PAC R-series controllers.
Video: Controllers: SNAP-PAC-R1 vs. -R2
A quick overview of SNAP-PAC-R1 vs -R2 controllers.
Video: Dual Ethernet Interfaces: Controllers vs. Brains
A quick overview of Dual Ethernet Interfaces: Controllers vs. Brains.
Video: EtherNet-IP for SNAP I/O
Sr. Systems Engineer James Davis demonstrates Configuring EtherNet/IP so A-B PLCs can use intelligent remote SNAP I/O. More info: IO4AB
Video: Using SNAP PAC System with Ethernet/ IP
A quick overview of how any device using the EtherNet/IP protocol from Allen-Bradley can communicate with Opto 22 SNAP PAC controllers and brains. More info: IO4AB
Video: Webinar: Controller Redundancy in PAC Control 9
Learn how to implement controller redundancy in SNAP PAC systems.
PID: Reaction Curve Tuning for Interactive PID algorithms
Tune your real-world PID control loop with this graphical tuner. Plug in your data and get calculated P, I, and D values, plus scan rate.
SNAP PAC Networking
Learn the basics about dual ports, redundancy, segmenting, and daisy chaining of SNAP-PAC networking in this interactive demo.
What is a PAC?
Learn all about Programmable Automation Controllers (PACs) including the history of the term PAC, PAC features, and Opto 22 PACs.
