SNAP-PS24U
SNAP-PS24U
$434.00 (USA and Canada only)
SNAP Power Supply, 100-250 VAC to 24 VDC
The SNAP-PS24U power supply provides 24 volts (1.25 amps) of DC power. This power supply is ideal for powering a SNAP PAC S-series controller (such as the SNAP-PAC-S1) or for providing loop power for SNAP analog modules mounted on a SNAP PAC rack.
AC power connections are made to a removable terminal strip on top of the power supply. DC output power is hooked up using the attached wiring harness.
If you need fewer amps and can use a 120 VAC input, see the SNAP-PS24, which provides 0.75 A.
NOTE: The SNAP-PS24U can also be used to provide loop power for analog modules on a SNAP M-series or B-series rack.
SNAP-PS24
SNAP-PS24U
Input Voltage
95–130 VAC, 47–63 Hz
100–250 VAC, 47–63 Hz
Output Voltage
24 ± 0.6 VDC
24 ± 0.1 VDC
Output Current
0.75 A
1.25 A
Maximum Input Current Draw
0.4 Amps @ 120 VAC
0.5 Amps @ 120 VAC
Dimensions
4.05˝ x 4.89˝ x 2.00˝
6.34˝ x 4.13˝ x 2.53˝
Weight
2.1 lbs (952.54 g)
1.9 lbs (863.63 g)
Operating Temperature
-20 to 70 °C
-20 to 70 °C
Storage Temperature
-30 to 85 °C
-30 to 85 °C
Torque, connector screws
4.5 in-lb (0.51 N-m)
Fuse
Opto 22 PN: SNAP-FUSE1AB Vendor PN: GDC-1A (Bussman)
Internal fuse
UL, CE, RoHS, DFARS
UL, CE, RoHS, DFARS
30 months
30 months
SNAP PAC System Product Guide
SNAP Power Supplies Data Sheet
SNAP power supplies provide the best source of AC or DC power for your Opto 22 SNAP PAC hardware. Packaged in a compact, sturdy housing, SNAP power supplies include a built-in fuse, an LED status indicator, and an ON/OFF power switch for ease of use.
This document provides information and specifications for the following part numbers:
SNAP-PSDIN Installation Note
This document describes how to install a SNAP DIN-RAIL mounting assembly.
