KB90566
Published: December 11, 2023
Uninstalling one version of PAC Project may result in a communication error with SoftPAC
SoftPAC
SoftPAC Monitor
All versions
If you have multiple versions of PAC Project installed (for example, 10.2, 10.4, and 10.5) and uninstall one version (such as 10.2), you may encounter a communication error when attempting to run SoftPAC or SoftPAC Monitor.
After you uninstall a version of PAC Project, install the latest PAC Project version (or the latest compatible version for your system).
