KB90748
Published: December 7, 2023
groov discrete input channel may not produce period, pulse, or frequency measurements
Firmware for the following groov I/O modules:
  • GRV-IAC-24
  • GRV-IACDCTTL-24
  • GRV-IACHV-24
  • GRV-IDC-24
  • GRV-IACI-12
  • GRV-IACIHV-12
  • GRV-IDCI-12
  • GRV-IDCSW-12
  • GRV-IDCIFQ-12
Versions lower than R1.3d for the following modules:
  • GRV-IAC-24
  • GRV-IACDCTTL-24
  • GRV-IACHV-24
  • GRV-IDC-24
  • GRV-IACI-12
  • GRV-IACIHV-12
  • GRV-IDCI-12
  • GRV-IDCSW-12
Versions lower than R1.3e for the following module:
  • ​GRV-IDCIFQ-12
  • GRV-IAC-24
  • GRV-IACDCTTL-24
  • GRV-IACHV-24
  • GRV-IDC-24
  • GRV-IACI-12
  • GRV-IACIHV-12
  • GRV-IDCI-12
  • GRV-IDCSW-12
  • ​GRV-IDCIFQ-12
Note: This issue applies only to users that configure their modules through OptoMMP. It does not apply to PAC Control nor CODESYS users.
For the affected modules, if a channel is configured with the following features, you may see the listed symptom:
  • Pulse or period measurements (one-time)—If a pulse or period is at frequencies above 5 kHz, the channel may not measure a subsequent pulse or period.
  • Frequency (one-time) feature—If there is no input signal (0 Hz), the channel may not report a measurement.
In the memory map, the channel's feature type is not cleared.
Reconfigure the channel with the pulse (one-time), period (one-time), or frequency (one-time) feature.
