KB90761
Published: December 7, 2023
Difference between the in-progress value and the final value of a period measurement
Firmware for the following groov I/O modules:
- GRV-IAC-24
- GRV-IACDCTTL-24
- GRV-IACHV-24
- GRV-IDC-24
- GRV-IACI-12
- GRV-IACIHV-12
- GRV-IDCI-12
- GRV-IDCSW-12
- GRV-IDCIFQ-12
For the following modules, all versions lower than R1.3d:
- GRV-IACI-12
- GRV-IACIHV-12
- GRV-IAC-24
- GRV-IACDCTTL-24
- GRV-IACHV-24
- GRV-IDC-24
- GRV-IDCI-12
- GRV-IDCSW-12
For the following modules, all previous lower than R1.3e:
For the following modules, R1.3d:
- GRV-IACI-12
- GRV-IACIHV-12
- GRV-IAC-24
- GRV-IACDCTTL-24
- GRV-IACHV-24
- GRV-IDC-24
- GRV-IDCI-12
- GRV-IDCSW-12
For the following modules, R1.3e:
If you read a period measurement before it finishes its cycle, the value will be inaccurate.
If you want to read the value even though the period completion status is false, store the value to an integer variable and then divide by 10,000.
