KB90809
Published: January 3, 2024
Generate N Pulses and some Analog Totalizer commands do not allow you to select a GRV-EPIC-PR2 as the I/O unit in PAC Control
PAC Control Basic
PAC Control Professional
R10.4a to R10.5b
R10.5c
In PAC Control, your GRV-EPIC-PR2 may not be available to select as the I/O unit when configuring the following commands:
- Generate N Pulses
- Get & Clear Analog Totalizer Value
- Get Analog Totalizer Value
- Set Analog Totalizer Rate
