Download this white paper as a pdf
What’s The Goal?
By now, most anyone working in a role involving industrial automation has heard about digital transformation, the internet of things (IoT), or the industrial IoT (IIoT). These initiatives involve ever smarter devices communicating progressively closer to the “edge,” perhaps connected to an internet “cloud,” or even through some kind of intermediate “fog.”
Even if we consolidate these terms under the umbrella of IIoT, for most folks a simple question remains: what is the goal of the IIoT?
Simply put, end users would like the IIoT to create a cohesive system of devices and applications able to share data seamlessly across machines, sites, and the enterprise to help them optimize production and discover new cost-saving opportunities.
Sharing process data has long been a goal of industrial automation, but traditional operational technology (OT) architectures are poor at scaling, priced prohibitively, and demand complex configuration and support.
So what is changing to achieve this new, more ambitious goal?
Much as consumer hardware and software technologies have shifted to improve ease-of-use and connectivity, industrial products and methods are following the same trend. By adopting information technology (IT) capabilities, they are making it easier to connect industrial equipment with computer networks, software, and services, both on premises and in the cloud.
This white paper discusses how a more distributed global architecture is enabling connectivity from the field to the cloud for sensors and actuators, and for the input/output (I/O) systems and controllers linked to them.
Traditional data acquisition methods require configuring and maintaining many layers in a hierarchy of hardware and software.
Up and Down the Architecture
Industrial automation architectures generally address data processing from a hierarchical perspective, as with the classic Purdue model. One good feature of this hierarchy is the clarity it provides with regard to where data can originate, be stored, undergo processing, and be delivered.
However, the task of transporting data and processing it in context is often quite difficult, because so many layers of equipment are required to connect devices and applications.
For example, the illustration above shows a traditional method of acquiring temperature data from facility equipment and moving it to a back-end client, like a database.
The lowest level of an automation architecture is made up of the physical devices residing on process and machinery equipment: sensors, valve actuators, motor starters, and so on. These are connected to the I/O points of control system programmable logic controllers (PLCs) and human-machine interfaces (HMIs), both of which are well suited for local control but less useful for advanced calculations and data processing.
However, using industrial communications protocols, these low-level devices can respond to data requests from upstream supervisory control and data acquisition (SCADA) systems where it might be historized or made available to corporate-level analytical software. Sharing data within multi-vendor systems, however, often requires additional middleware, such as OPC device drivers, to translate the various industrial protocols.
More advanced site manufacturing execution system (MES) and overall enterprise resource planning (ERP) software also reside at higher levels of the architecture, hosted on PCs or servers on site or in the cloud, where the cloud is defined as large-scale, internet-based, shared computing and storage.
Information generally flows up to higher levels to be analyzed and used to optimize operations, but the middle layers are required in order to interpret, translate, filter, and format the raw data produced by low-level devices and protocols.
Since these low-level devices typically lack protection against cyber-intrusion, a clear division must also be maintained between high-level systems exposed to external networks and low-level systems.
Developments over the past decade are significantly altering this traditional hierarchy, flattening and simplifying it to a great extent.
