Alta Forest Products grows new HMI
World’s largest producer of fence boards improves efficiency with data visualization
Walk into the fencing department of your local home improvement store, and you’re likely to find Alta Forest Products wood fencing prominently featured.
Whether you’re looking for naturally bug- and decay-resistant Western Red Cedar, or pre-stained wood like Douglas Fir or whitewood, you’ll find the boards you need to build your own fence or have a builder install it for you.
The world's largest producer of wood fence boards, Alta Forest Products, LLC, is headquartered in Chehalis, Washington, and runs four sawmills in Washington and Idaho. The four mills produce enough fence boards every year to build a fence from Seattle to Atlanta and back—twice!
Shipping more than 2,000 rail cars and 8,000 flatbed trucks and vans of lumber each year, the company also ships enough chips, bark and sawdust to total more than 13,000 outbound truckloads annually.
Alta Forest Products is the world’s largest producer of wood fence boards.
Zero Wood Waste
Since 2014 Alta has invested heavily in capital improvements to redesign handling and processing systems at its mills, to improve efficiency and reduce waste. The result? It’s now a zero-wood-waste organization.
Any wood fiber not suited to produce a solid board is converted into wood chips, which are sold to pulp and paper manufacturers in the region and used as groundcover for children’s playgrounds.
Wood not suited for boards is sold as wood chips. Bark and sawdust are sold as well.
The Challenge
In addition to chips, Alta collects bark from the outside of the logs it consumes and sells it as mulch. Sawdust generated by the mills is sold to chicken farmers for bedding and used to make specialty soils for farming and gardening. Any remaining material becomes biofuel for local co-generation facilities.
With all these improvements to the process and handling systems at their mills, the need for visibility into operations and system data soon became clear. Supervisory personnel wanted a broad overview of the facility, and they also needed to see critical KPIs (key performance indicators) for each machine center.
Existing data collection was a cumbersome, home-brewed solution involving Microsoft® Excel, SQL, and Visual Basic. It wasn’t scalable as it was, and it would be too expensive to expand it to support the expected number of clients. In addition, it had no real provision for mobile users.
HMI (human-machine interface) systems like this are typically created by OEM vendors, who offer packaged solutions. But Alta wanted more flexibility to customize their HMI, plus a lower cost per location and per user.
The company’s sawmill at Shelton, Washington, one of four sawmills in the U.S. Northwest
The Solution
Specifically, the company looked for an inexpensive but capable HMI that they could easily develop, deploy, and customize for an individual sawmill, with no tag, screen, or user limitations. They considered several solutions but rejected them due to restrictive licensing, limits, and expense.
After an extensive Internet search and discussion with peers in the industry, Alta found Opto 22’s groov® View.
“We were able to try groov View for free and could immediately see how easy it was to build an HMI that we could use on mobile and PC clients, with any browser,” says Geoff Eastman, Controls Manager. “In addition, since it’s browser based, any PC workstation can be used to develop or change the interface.”
Starting with groov Server for Windows™, which runs on a Microsoft Windows® PC, the company soon found the groov Edge Appliance (groov Box™) worked even better for their purpose. The groov Box is industrially hardened and can be placed in tough locations where a PC could fail. It also offers built-in security and additional features for industrial internet of things (IIoT) uses.
Both groov products include groov View software for building and viewing an HMI. groov View’s drag-drop-tag interface shortens the time needed to build an interface.
Once built, the interface can be viewed by authorized users from any device with a web browser, from a smartphone to a web-enabled HDTV. The software requires no keys or user fees and has no user or device limits.
Many sawmill processes at Alta Forest Products are controlled by Allen-Bradley® ControlLogix® or SLC-500 control systems. The groov View software connects to these PLC systems and provides data, monitoring, and even control if users have authorization.
The company maintains secure firewall-to-firewall connections over the internet for its five discrete locations—headquarters and four sawmills—so data from all locations can be securely accessed within the HMI.
Critical KPIs are now available for machines such as this mill stacker.
Trends in groov View track a wide variety of data, including motor current, residual bunker levels for sawdust and chips, black water tank levels, temperature and flow, log diameter, and production rates.
Meaningful KPIs for each machine center are available live in the groov View HMI. Node-RED, included in the groov Box, pushes historical data to Domo®, a business intelligence web interface. Once in Domo, supervisors and other clients can customize reports to their needs.
Data from groov View is also logged to mySQL, again accessed via Domo. Authorized users also receive alerts and warnings based on preset conditions; these alerts are delivered via email or text message.
Says Eastman, “Our new HMI was easy to implement and requires no client-side licensing or updates. There’s minimal troubleshooting and upkeep, and Opto 22 provides prompt technical support when we need it.
“With this interface we can easily visualize data from any location. We can accommodate employee requests for specific data or graphics from any PC at any site. Our engineering department can anticipate and respond to problems quickly. Management can track production and make better decisions based on real data.”
And that helps make the world’s largest producer of fence boards even more efficient.
For more information on Alta Forest Products, visit their website at https://www.altafp.com.
Download case study pdf
Alta Forest Products’ groov View HMI (partly shown here on a smartphone) gives operators and managers real-time displays for sawmill equipment as well as trends and KPIs.
Order now!
