The B3000-HA is obsolete and no longer available. There is no direct replacement.
Depending on your application, you may be able to use a
B3000-B brain with RS-485 instead of twisted-pair Arcnet, or you may want to migrate to the
SNAP PAC System.
Please contact Opto 22
Pre-Sales engineers with details about your specific application so they can help recommend parts.
NOTE: If you already have a B3000-HA and need additional I/O, note that not all SNAP I/O modules are compatible with this brain.
See
Legacy and Current Product Comparison and Compatibility Charts for compatibility information.
Power Requirements
5.0 - 5.2 VDC at 1.0A max.
Operating Temperature
0 to 70 °C, 5–95% humidity, non-condensing
CPU
16-bit Intel 80C196 I/O processor
Communications Interface
Node 0 and Node 1; twisted-pair ARCNET at 2.5 megabits per
second. Either port can be used, or both ports can be used for
redundant processor-to-I/O communication.
Data Rates
2.5 megabits per second; baud jumpers, although present, have
no effect.
Range (Multidrop Mode):
Up to 1,000 feet with up to 17 nodes. Repeaters and conversion
from Coax cable are commercially available.
Counter/Frequency Measurement
Maximum Rate: 20 kHz
Minimum Pulse Width: 10 µsec
Output Pulse
Maximum Rate: 500 Hz
Minimum Pulse Width: 1 msec
PID Update Rate
100 msec (for 1 to 8 PID loops)
LED Indicators
RUN (Power On), XMT (Activity), PGM (Program), and COM ports
Options: Jumper Selectable
Address, Node 0 Termination, Node 1 Termination
Cable
CAT-3 or CAT-5 UTP
The SNAP-B3000-HA processor is used to remotely control a mix of both analog and digital I/O modules using Opto 22's SNAP B-Series I/O mounting racks.
This technical note shows you how to set offset and gain for Opto 22 analog input modules.
