$0.00 (USA and Canada only)
The GROOV-AT1 FAN KIT is a replacement part for the GROOV-AT1 Box. The kit includes one entire assembled end piece containing two fans.
To install:
This user's guide shows you how to set up and configure a groov Box, part number GROOV-AT1 or GROOV-AT1-SNAP and the GROOV-AT1 FAN KIT. You can use groov to develop an operator interface to monitor and control your automation systems and equipment. Note: If you have the newer groov Box (part numbers GROOV-AR1-BASE, GROOV-AR1, or GROOV-AR1-SNAP), do not use this guide. Instead, see Form 2104, groov Box User's Guide for GROOV AR1.
This CAD file contains a 3-dimensional drawing of the GROOV-AT1 groov Box, which contains all groov software. With groov, you can easily build effective operator interfaces for your control system and view them on any device with a modern web browser—computers, tablets, smartphones, even an HDTV—any screen size, any manufacturer.
For more information, see groov System.
$2,895.00
$1,995.00
