GROOV-LIC-ENT
GROOV-LIC-ENT
OBSOLETE groov Base upgrade to Enterprise License
*** NOTE: This product is obsolete. You do not need to buy this license. ***
If you have an older groov Box or groov Server that limits your use of an external OPC UA server, log into manage.groov.com and click the Manage button. Find your groov in the list and click the Manage button next to it. Install the latest version of groov View and also download and install the license file.
When added to a groov product (GRV-EPIC-PR1, GROOV-AR1-BASE, or GROOV-SVR-WIN-BASE), this groov Enterprise license let you monitor and control all kinds of OPC UA-compatible systems and equipment, in addition to multiple Modbus/TCP devices, Data Stores, Opto 22 groov EPIC and SNAP PAC controllers (SNAP PAC R-series, S-series, SoftPAC), SNAP PAC I/O units, and OptoEMU Sensor energy monitoring units. The Enterprise license also let you use MQTT/Sparkplug in Ignition Edge, which is included in groov EPIC and the groov Box.
This groov Enterprise license used to be required for:
  • Using the Ignition Edge internal OPC-UA server & drivers in groov EPIC or the groov Box
  • Using MQTT/Sparkplug in Ignition Edge in groov EPIC or the groov Box
  • Using any external OPC-UA server with groov EPIC, the groov Box, or the Microsoft Windows-based groov Server for Windows
To use GROOV-LIC-ENT, you must also have a groov EPIC processor (GRV-EPIC-PR1), a groov Box (GROOV-AR1-BASE), or groov Server for Windows (GROOV-SVR-WIN-BASE).
An OPC UA server is required to communicate with OPC UA-compatible systems and equipment. If you have groov EPIC or a groov Box, you can use the Ignition Edge internal OPC-UA server and drivers. If you need an external OPC-UA server, we recommend Kepware Technologies' KEPServerEX.
NOTE: When activating your groov, activate the EPIC, Box, or Server first, and then activate GROOV-LIC-ENT.
If you have groov EPIC or a groov Box, then email Opto 22 at pcs@opto22.com to receive your free license for Ignition Edge.
