OPTOEMU-SNR-DR1
OPTOEMU-SNR-DR1
OBSOLETE Energy monitoring unit with Demand Response capability (Wired+Wireless)
NOTE: This product is obsolete and no longer available, due to the unavailability of essential components required to manufacture it. If you can use wired Ethernet communications, see the OPTOEMU-SNR-DR2 instead.
The OPTOEMU-SNR-DR1 energy monitoring unit monitors the electrical energy used in your facility and then signals electrical equipment to turn on or off in response to a request from an electric utility, demand response aggregator, or curtailment service provider (CSP). To reduce peak energy use that triggers demand charges, electrical equipment loads can also be shed on predefined usage thresholds.
OPTOEMU-SNR-DR1 monitors up to two KY or KYZ pulsing devices, such as a pulsing meter or submeter, and up to 64 data inputs from Modbus devices over serial and Ethernet. The unit sends this data to an online service of your choosing, so you can see and analyze energy usage. The unit can also send energy data to control systems and company databases.
The unit's four signal relay outputs can be used to automatically respond to a DR event by signaling equipment such as HVAC fans and chillers to turn on or off, or signaling existing energy or building management systems to perform load shedding. Each Form C output can be wired for normally open or normally closed.
An easy-to-use utility program for configuring the unit is included. You can download this OptoEMU Sensor Manager for free; it also comes on a CD with the Sensor.
The OPTOEMU-SNR-DR1 communicates with online services and computer networks over a standard 10/100 Mbps wired Ethernet network, over an 802.11a/b/g wireless LAN (local area network), or over both simultaneously.
If you do not need WLAN capability, see the OPTOEMU-SNR-DR2.
If you need to monitor voltage and current directly from an electrical panel or electrical equipment (not through a pulsing meter or Modbus device), see the OPTOEMU-SNR-3V.
Overall Unit Specifications
[OBSOLETE] OPTOEMU-SNR-DR1
OPTOEMU-SNR-DR2
Power Requirements
100–240 VAC, 47–63 Hz, 0.4 A maximum, 8 W
Dimensions
Overall 2.45" w x 8.08" h x 4.76" d (6.23 cm x 20.53 cm x 12.09 cm)
Enclosure
Sturdy metal case
Sturdy metal case
Removable storage
MicroSD card slot (for future use)
Backup battery
Rechargeable (recharges whenever the unit has power), 3-year power-off data retention
Ethernet Communication (wired)
Two independent 10/100 Mbps Ethernet network interfaces (RJ-45 connectors), each with a sepa­rate IP address (separate subnets).
Two independent 10/100 Mbps Ethernet net­work interfaces (RJ-45 connectors), each with a separate IP address (separate subnets).
Ethernet Comm (wireless)
Wireless LAN interface with separate IP address (separate subnet).
Security:
AES - Compatible with WPA2 Personal (802.11i);
TKIP - Compatible with WPA Personal
Frequency 802.11a:
5.180–5.240 GHz, 5.745–5.825 GHz
Frequency 802.11b/g:
2.412–2.472 GHz, 2.484 GHz
Transmit Power:
15 dBm maximum
Antenna Connector:
Reverse polarity SMA (RP-SMA or RSMA)
Roaming:
Supported within an SSID (Service Set Identifier) only
No wireless capability
Serial Communication
One serial port, software configurable for RS-232 (TX, RX, COM, DTR, DCD, RTS, CTS) or RS-485 (2-wire, 4-wire, optional termination, optional biasing).
Indicators
Status of unit
Wireless: WLAN activity
Serial: Receiving, Transmitting (future use)
Ethernet interfaces (2): Link, Activity
Pulse inputs: On/Off status
Mechanical relay outputs: On/Off status
Status of unit
Other features
Real-time clock
Real-time clock
Operating Temperature
0 to 60 °C (32 to 140° F)
Storage Temperature
-25 to 85 °C (-13 to 185° F)
Humidity
0% to 95% relative humidity, non-condensing
UL, cUL, DFARS
Wireless: U.S., FCC Part 15 Subpart C; Canada, IC RSS-210
UL, cUL, CE, RoHS, DFARS
30 months
30 months
Dry Contact Pulse Inputs
OptoEMU Sensor DR supplies 15 volts to each external dry contact switch and senses switch closure.
Open Circuit Voltage (Switch Open)
15 VDC typical (supplied by OptoEMU Sensor DR)
Short Circuit Current (Switch Closed)
7 milliamps nominal
Minimum Off Resistance
>20 K ohms
Maximum Allowable ON Resistance
(Wire + Contact Resistance)
500 ohms
Turn-on Time
5 msec
Turn-off Time
25 msec
Input-to-output Isolation
1500 VAC/VDC
Minimum Pulse Width
>=7 milliseconds
Maximum Frequency
<=30 Hz
Status indicators
1 LED per channel
Signal Relay Outputs
Contact Configuration
SPDT relay (with NO and NC contacts)
Line Voltage - Range
0–240 VAC or 0–30 VDC
Current Rating
100 mA switching @ 0 240 VAC or 0 100 VDC 100
Surge Current
600 mA
Minimum Load
0.1 VDC, 5 mA
Contact Resistance
100 milliohms
Peak Blocking Voltage
250 VAC/VDC
Channel-to-channel isolation
300 VAC (1500 V transient)
Turn-on Time
6 milliseconds
Turn-off Time
6 milliseconds
Temperature
0 to 70 °C, operating
-30 to 85 °C, storage
Mechanical Life
5 x 106 operations
Operational Life
1 x 103 operations
Status indicators
1 LED per channel
OptoEMU Sensor DR (Demand Response) Data Sheet
The OptoEMU Sensor™ Energy Monitoring Unit with Demand Response (DR) monitors the electrical energy used in your facility and then signals electrical equipment to turn on or off in response to a request from an electric utility, demand response aggregator, or curtailment service provider (CSP).
The OptoEMU Sensor DR makes it easy to reduce your energy costs by managing energy consumption, taking advantage of demand response programs, and gaining control over your energy pricing.
OptoEMU Sensor Manager Readme
This documents lists the new features, enhancements and bug fixes for the OptoEMU Sensor Manager.
OptoEMU Sensor Update File Readme
This documents lists the new features, enhancements and bug fixes for OptoEMU Sensor energy monitoring units (OPTOEMU-SNR-3V, OPTOEMU-SNR-DR1, and OPTOEMU-SNR-DR2).
Quick Start: Energy Monitoring HMI for OptoEMU Sensor
The Energy Monitoring HMI (human-machine interface) for OptoEMU Sensor gives you a simple way to see the energy your facility is using, so you can analyze this detailed data and take steps to reduce energy costs.
The Energy Monitoring HMI displays data from one OptoEMU Sensor (any model).
This Quick Start guide shows you how to install and use the Energy Monitoring HMI.
OptoEMU Sensor Communication Guide
OptoEMU Sensor™ Energy Monitoring Units monitor the electrical energy used in your facility and then deliver that data to applications so you can see it, analyze it, and take steps to reduce energy costs.
The OptoEMU Sensor can provide data to web-based or local software services; to control systems based on Opto 22’s PAC Project™ software and Modbus/TCP; to OPC clients; and to standard SQL databases. This Communication Guide shows you how to communicate with the Sensor in all these ways.
NOTE: To install and use the OptoEMU Sensor and see energy data through online software services such as Pulse Energy and eSight, see Form 1932, OptoEMU Sensor User's Guide. If you are using the Sensor only with these online services, you do not need this Communication Guide.
The OptoEMU Sensor monitors energy usage in your facility so you can track energy data and reduce costs. This document describes how to install and use the OptoEMU Sensor and the optional auxiliary box.
Application Brief: Integrating M-Bus Sensors with an Energy Monitoring System
In Gothenburg, Sweden, water, temperature, and power sensors in a modern apartment building deliver real-time usage information to an OptoEMU energy monitoring system using an Anybus M-Bus to Modbus/TCP gateway.
Opto 22 To Present OptoEMU Sensor Energy Management Products at World Energy Engineering Congress
Press release: Opto 22 To Present OptoEMU Sensor Energy Management Products at World Energy Engineering Congress 2012.
Demand-Response Energy Monitoring Unit from Opto 22 Monitors Real-Time Power Usage and Manages Electrical Loads on Demand
The OptoEMU Sensor DR energy monitoring unit from Opto 22 monitors the electrical energy used in your facility and then signals electrical equipment to turn on or off in response to a request from an electric utility, demand response aggregator, or curtailment service provider (CSP). To reduce peak energy use that triggers demand charges, electrical equipment loads can also be shed on predefined usage thresholds.
OptoEMU Sensor DR Quick Start Card
The OptoEMU Sensor DR monitors energy usage in your building or facility and sends energy data so you can see it online and use it in building and control systems. You can analyze patterns, identify ways to reduce energy costs, and respond to demand response (DR) events either manually or automatically.
The OptoEMU Sensor DR Quick Start Card shows you how to begin using the OptoEMU Sensor DR. For more detailed steps, see Form 1932, OptoEMU Sensor User's Guide.
Energy Monitoring for Profit: Introducing Demand Response
This white paper introduces the concept of demand response (DR) in energy management. DR offers an opportunity for industrial and commercial businesses to not just reduce energy costs, but also earn a revenue stream from their use of electrical energy.
The paper briefly discusses how electrical energy is produced and distributed in the United States and then describes four practical steps automation professionals can begin now to take advantage of DR programs in their area.
Energy Monitoring Made Simple
This two-page, full-color brochure describes the OptoEMU Sensor energy monitoring unit, including diagrams, brief description, and specifications.
For more detailed data, see Form 1936, OptoEMU Sensor 3V data sheet and Form 1990, OptoEMU Sensor DR data sheet.
Automation and the Smart Grid: Energy Management Today
This white paper looks at the way electricity is produced in the United States today and the vision for a "Smart Grid" in the future.
The paper also discusses specific ways that small and medium-sized industrial and commercial businesses can manage electrical usage and costs today, without waiting for Smart Grid technology.
This file updates an OptoEMU Sensor (OPTOEMU-SNR-3V, OPTOEMU-SNR-DR1, or OPTOEMU-SNR-DR2) to use current firmware and software.
You must have OptoEMU Sensor Manager software in order to install this update file. For update instructions, see the Maintenance chapter in the OptoEMU Sensor User’s Guide (form 1932).
OptoEMU Sensor Data-Sharing Strategy
This is a PAC Control strategy tag database (idb) file that enables you to access energy data in the OptoEMU sensor for use by PAC Display HMIs, OPC clients, and common SQL databases.
You do not need this file unless you are using data from the Sensor in one of these ways.
If you need this file, download it and save it to a permanent location on your PC. Read the OptoEMU Sensor Communication Guide (form 1958) for details on how to use the Data-Sharing Strategy.
OptoEMU Sensor.idb.txt File
If you are using groov to build operator interfaces (HMIs) for an OptoEMU Sensor energy monitoring unit, you need this file.
This text file contains the tag database information from the OptoEMU Sensor. Download this file and then follow instructions in the groov Quick Start or groov User's Guide to create your HMI.
groov makes it simple to build HMIs using only a web browser, and to view HMIs on any device—computer, laptop, tablet, smartphone, and more—that uses a modern web browser, no matter its size or manufacturer. For more information, see groov.
