OUTPUT SWITCH
OUTPUT SWITCH
$43.00 (USA and Canada only)
OBSOLETE Output Switch, 250 VAC
The output test module provides a manual toggle switch on the field side. The toggle switch closes a contact that shorts the field terminals to turn on a field device. Internally, there is no connection to the logic side of the module.
The output test module is ideal for testing field wiring and field devices by simulating an output from the computer. The switch handles 3A @ 250 VAC.
Agency Approvals: CE, RoHS; UKCA
Standard Digital Output Test Module Data Sheet
The output test module is a device that provides a manual toggle switch on the field side ideal for testing field wiring and field devices by simulating an output from the computer.
