SNAP-AIARMS-i-FM
SNAP-AIARMS-i-FM
OBSOLETE SNAP Isolated 2-Ch 0-10 amp RMS Analog Input Module
Please consider SNAP-AIARMS-i or contact Opto 22 Pre-Sales engineers for more information.
The SNAP-AIARMS-i-FM module provides two isolated channels with an input range of 0 to 10 amps RMS AC/DC. An ideal input is the 5-amp secondary of a standard current transformer used to monitor AC line current. The module may also be used to monitor AC current to greater than a 100-amp range, using a current transformer of suitable ratio.
The two channels are isolated from each other; they do not share any field connection. The SNAP-AIARMS-i-FM module is an excellent choice for differential current measurements.
If you do not need channel-to-channel isolation, see SNAP-AIARMS.
Input Range
0 to 10 amp RMS AC/DC
Input Over Range
To 11 amps
Input Resistance
0.005 ohms
Maximum Input
11 amps AC/DC
Accuracy (AC)
±8 mA and ±0.2% reading
Resolution
400 µA
DC Reversal
±16 mA (0.16%)
Input Response Time
(Step Change)
63.2% (6.32 A) in 50 ms
99% (9.92 A) in 75 ms
Data Freshness (Max)
0.025 ms
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB at 60 Hz
Maximum Operating
  Voltage Between Channels
  Common Mode Voltage
250 V
250 V
Isolation: Optical
4000 V
Isolation: Transformer
1500 V
Isolation: Channel to Channel
250 V continuous
(1500 V transient)
Power Requirements
5 VDC (±0.15 V) at 200 mA
Ambient Temperature:
  Storage
-20 °C to 70 °C
-25 °C to 85 °C
Humidity
5-95%, non-condensing
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
CE, RoHS, DFARS; UKCA
Lifetime
Obsolete SNAP Analog I/O Modules Technical Note
This technical note contains information you may need about OBSOLETE SNAP analog I/O modules you’re still
using. Included are part numbers, descriptions, specifications, wiring diagrams, and dimensional drawings.
These parts have been removed from data sheets because we no longer sell them.
This document includes information on the following obsolete SNAP analog I/O modules:
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
