SNAP-AICTD
SNAP-AICTD
$296.00 (USA and Canada only)
SNAP 2-Ch Analog Temperature Input Module - ICTD
The SNAP-AICTD provides two channels of analog temperature input from any industry-standard Integrated Circuit Temperature Device (ICTD). Simple two-wire connections are made to the pluggable terminal strip on top of the module. Although the two channels are not isolated from each other, the module is transformer isolated and optically isolated from other modules and devices.
Need more channels? See the 4-channel SNAP-AICTD-4 or the 8-channel SNAP-AICTD-8.
Input Range with ICTD Probe
-40 °C to +100 °C
Module Input Range
 Zero Scale
 Full Scale
-273 °C
+150 °C
Resolution
0.017 °C
Accuracy with ICTD Probe
±0.8 °C
Sensitivity
1.0 microamps/ °C
Data Freshness (Max)
167 ms (2-channel module)
355 ms (4-channel module)
DC Common Mode Rejec­tion
>-120 dB
AC Common Mode Rejec­tion
>-120 dB @ 60 Hz
Maximum Operating Com­mon Mode Voltage
250 V
Isolation
1500 V
Power Requirements
5 VDC (± .015 ) @ 150 mA
Operating Temperature
-20 °C to 70 °C
Storage Temperature
-40 °C to 85 °C
Humidity
5-95%, non-condensing
Wire size
22 to 14 AWG
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
UL, CE, RoHS, DFARS; UKCA
Lifetime
SNAP PAC System Product Guide
SNAP Analog Input Modules Data Sheet
SNAP I/O analog input modules are part of Opto 22's SNAP PAC System. This document includes descriptions, specifications, and wiring and dimensional diagrams for the following analog input modules:
For analog modules with channel-to-channel isolation, see Form 1182, the SNAP Isolated Analog Input Modules Data Sheet.
I/O Solutions for Temperature Monitoring (Chinese)
This white paper describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
Primer: I/O Solutions for Temperature Monitoring
This primer describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
Video: Securing SNAP Module
Video: Removing a SNAP Module
Video: I/O Solutions for Temperature Monitoring
A quick overview on I/O Solutions for temperature monitoring.
Video: Automation 101: Wire a Temperature Sensor
Learn how you can wire a temperature sensor to monitor temperature in key places like server rooms, so you can fix problems before your equipment fails.
Accuracy vs Resolution
