$393.00 (USA and Canada only)
Input Range with ICTD Probe
-40 °C to +100 °C
Module Input Range Zero Scale Full Scale
-273 °C +150 °C
Resolution
0.017 °C
Accuracy with ICTD Probe
±0.8 °C
Sensitivity
1.0 microamps/ °C
Data Freshness (Max)
167 ms (2-channel module) 355 ms (4-channel module)
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB @ 60 Hz
250 V
Isolation
1500 V
Power Requirements
5 VDC (± .015 ) @ 150 mA
Operating Temperature
-20 °C to 70 °C
Storage Temperature
-40 °C to 85 °C
Humidity
5-95%, non-condensing
Wire size
22 to 14 AWG
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
UL, CE, RoHS, DFARS; UKCA
Lifetime
This document lists and describes all current Opto 22 SNAP PAC System part numbers, including PAC Project software, SNAP PAC controllers, and SNAP I/O modules of all kinds. SNAP PAC mounting racks and SNAP power supplies are also listed.
SNAP I/O analog input modules are part of Opto 22's SNAP PAC System. This document includes descriptions, specifications, and wiring and dimensional diagrams for the following analog input modules:
This white paper describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
This primer describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
This document lists all Opto 22 part numbers that have the Underwriters Laboratory (UL) approval.
A quick overview on I/O Solutions for temperature monitoring.
$75.75
$104.00
$110.00
$128.00
