SNAP-AIMA-32-FM
SNAP-AIMA-32-FM
OBSOLETE SNAP 32-Ch -20mA to +20mA Analog Current Input Module
Please consider SNAP-AIMA-32 or contact Opto 22 Pre-Sales engineers for more information.
The SNAP-AIMA-32-FM provides 32 channels of -20 mA to +20 mA analog current input. The module does not supply loop excitation current. Although the 32 channels are not isolated from each other, the module is transformer isolated and optically isolated from other modules and devices.
CAUTION: We strongly recommend that you use the SNAP-AIMA-HDB breakout rack and SNAP-HD-BF6 wiring harness with this module. Miswiring of any point on the module can cause severe damage; the breakout rack protects the module from many wiring errors.
Compatibility: This module can be used only with SNAP PAC brains and R-series controllers. See SNAP-AIMA for a two-channel module that can also be used with legacy SNAP Ethernet and serial brains.
For a similar module that provides two isolated channels, see SNAP-AIMA-i.
For a module that provides two isolated channels and supplies loop excitation, see SNAP-AIMA-iSRC.
Input Range
-20 mA to +20 mA
Over-Range Limits
From -22 to +22 mA
(+/-20 mA range)
Resolution
0.8 microamps
Input Filtering
-3 dB @ 31 Hz
Data Freshness (Max)
1.15 s
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB @ 60 Hz
Maximum Survivable Input
36 mA or 9 VDC
250 V
Accuracy
0.1% (20 microamps)
DRIFT: Gain Temperature Coefficient
30 PPM/ °C
DRIFT: Offset Temperature Coefficient
15 PPM/ °C
Isolation
1500 V, field to logic
Power Requirements
5 VDC (±0.15 ) @ 150 mA
Input Resistance - Single Ended
100 ohms (each channel)
Operating Temperature
-20 °C to 70 °C
Storage Temperature
-40 °C to 85 °C
Humidity
5-95%, non-condensing
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
CE, RoHS, DFARS; UKCA
Lifetime
Obsolete SNAP Analog I/O Modules Technical Note
This technical note contains information you may need about OBSOLETE SNAP analog I/O modules you’re still
using. Included are part numbers, descriptions, specifications, wiring diagrams, and dimensional drawings.
These parts have been removed from data sheets because we no longer sell them.
This document includes information on the following obsolete SNAP analog I/O modules:
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
