SNAP-AIR400K-8
SNAP-AIR400K-8
$600.00 (USA and Canada only)
SNAP 8-Ch Analog Resistor/thermistor Input, 400 K Ohms
The SNAP-AIR400K-8 module has eight channels of analog to digital conversion that convert resistance to temperature or to ohms. The module is ideal for NTC thermisters commonly used in HVAC, refrigeration, and process control applications. It may also be used with PTC thermisters in resistance sensing applications.
The SNAP-AIR400K-8 reads variable resistance type transducers, and it has 12 resistance input ranges from 500 Ohms to 400 K Ohms, plus Autorange. Range dependent resolution is from 20 milliohms to 16 Ohms. SNAP PAC brains and PAC Control provide direct temperature readings for four popular thermistors using the Steinhart-Hart equation. You may also enter custom coefficients for unsupported thermistor curves.
Compatibility: This module can be used with SNAP PAC brains and R-series controllers. Minimum requirements: brain or controller firmware R9.3c and PAC Project R9.3002 (PAC Control R9.3b).
Also see the 4-channel SNAP-AIR40K-4.
Build your system in the SNAP PAC Configurator.
Input Ranges
400 K, 200 K, 100 K, 50 K, 40 K, 20 K, 10 K, 5 K , 4 K, 2 K, 1 K, 500 Ohms, and Autorange
Resolution
Resolution
16 Ohm
  8 Ohm
  4 Ohm
  2 Ohm
Range
0 to 400 kOhms
0 to 200 kOhms
0 to 100 kOhms
0 to   50 kOhms
Resolution
1.6 Ohm
0.8 Ohm
0.4 Ohm
0.2 Ohm
Range
0 to 40 kOhms
0 to 20 kOhms
0 to 10 kOhms
0  to  5 kOhms
Resolution
0.16 Ohm
0.08 Ohm
0.04 Ohm
0.02 Ohm
Range
0 to 4 kOhms
0 to 2 kOhms
0 to 1 kOhms
0 to 500 Ohms
Accuracy
(Ohms @ Range)
400 Ohms @ 400 K
200 Ohms @ 200 K
100 Ohms @ 100 K
  50 Ohms @   50 K
 40 Ohms @ 40 K
 20 Ohms @ 20 K
 10 Ohms @ 10 K
   5 Ohms @   5 K
4   Ohms  @ 4 K
2   Ohms  @ 2 K
1   Ohms  @ 1 K
0.5 Ohms @ 500
Data Freshness
1.61 seconds maximum
DSP Notch Filter
20 Hz (- 3DB = 5.24 Hz)
Excitation Current Nomi­nal (Range & Load Watts Dissipation)
9uA (50 K–4.1 uW), (100 K–8.1 uW), (200 K–16 uW), (400 K–32 uW)
90uA (5 K–40 uW), (10 K–81 uW), (20 K–160 uW), (40 K–320 uW)
200uA (500 K–20 uW), (1 K–40 uW), (2 K–80 uW), (4 K–160 uW)
Autorange Step Time
1.6 seconds to next higher or lower range
>= 10 seconds for a 500 Ohms to 400 K Ohms step change
Autorange Ohms Hyster­esis
                                Ranges
Ohms    Open  >  440K
20K      between 200K & 400K
10K      between 100K & 200K
5K        between 50K & 100K
19K      between
40K & 50K
2K        between 20K & 40K
1K        between 10K & 20K
500       between 5K & 10K
1.9K      between 4K & 5K
200       between 2K & 4K
100       between 1K & 2K
50         between 500 & 1K
DC Common Mode Rejec­tion
>-120 dB
AC Common Mode Rejec­tion
>-120 dB @ 60 Hz
Open Resistor Indicator
Channel resistance = 999,999.999 Ohms
PAC Control Reads
temperature reading or -32768 Ohms if over or under range
(Field Term to Logic Con­nector)
500 VDC or peak VAC
Drift
Gain Tempco
Offset Tempco
30 PPM / °C
15 PPM / °C
Power Requirements
5 VDC (±0.15 ) @ 190 mA
Operating Temperature
-20 °C to 70 °C
Storage Temperature
-40 °C to 85 °C
Humidity
5-95%, non-condensing
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
UL, CE; UKCA
Lifetime
SNAP Analog Input Modules Data Sheet
SNAP I/O analog input modules are part of Opto 22's SNAP PAC System. This document includes descriptions, specifications, and wiring and dimensional diagrams for the following analog input modules:
For analog modules with channel-to-channel isolation, see Form 1182, the SNAP Isolated Analog Input Modules Data Sheet.
Primer: I/O Solutions for Temperature Monitoring
This primer describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
Video: I/O Solutions for Temperature Monitoring
A quick overview on I/O Solutions for temperature monitoring.
