SNAP-AIRTD-10
SNAP-AIRTD-10
$370.00 (USA and Canada only)
SNAP 2-Ch 10-Ohm Copper RTD Analog Temperature Input
The SNAP-AIRTD-10 provides two channels of analog temperature input. Nominal input range is -180 to +260 degrees C. Although the two channels are not isolated from each other, the module is transformer isolated and optically isolated from other modules and devices. Modules are factory calibrated.
The SNAP-AIRTD-10 uses 10 ohm copper inputs. For other similar modules, see the SNAP-AIRTD (100 ohm platinum) and the SNAP-AIRTD-1K (1000 ohm platinum).
SNAP-AIRTD-1K
SNAP-AIRTD
SNAP-AIRTD-10
3-wire RTD input
1000 ohm platinum @ 0 °C α= 0.00385
1000 ohm nickel @ 0 °C
α= 0.00618
1000 ohm nickel @ 70 °F
α= 0.00637
100 ohm platinum; α= 0.00385
100 ohm nickel, -60 to 250 °C
120 ohm nickel, -80 to 260 °C
10 ohm copper; α= 0.00428
Input Temperature Range
-200 °C to 850 °C
(-328° to +1,582° F)
-200 °C to 850 °C
-180 °C to 260 °C
(-292° to +500° F)
Input Range
0 to 4000 ohms
0 to 400 ohms
0 to 25 ohms
Over-Range Limit
to 4400 ohms
to 440 ohms
to 27.5 ohms
Resolution (average)
0.042 °C (0.16 ohms)
0.042 °C (0.016 ohms)
0.026 °C (0.001 ohms)
Input Filtering
-3 dB @ 0.1 Hz
-3 dB @ 0.1 Hz
-3 dB @ 100 Hz
Data Freshness (Max)
100 ms
100 ms
168 ms
Lead Compensation
Automatic when used with SNAP brains
Automatic when used with SNAP PAC brains
DC Common Mode Rejection
>-120 dB
>-120 dB
>-120 dB
AC Common Mode Rejection
>-120 dB at 60 Hz
>-120 dB at 60 Hz
>-120 dB at 60 Hz
Excitation (typical)
0.256 mA constant current
1.25 mA constant current
5.4 mA constant current
Maximum Lead Resistance
40 ohms single wire (all leads to be equal resistance)
15 ohms single wire (all leads to be equal resistance)
Maximum Fault Voltage at Input
(between any 2 field wires)
±15 V
±15 V
±15 V
250 V
250 V
250 V
Accuracy
 From factory
 After setting gain and offset
0.8 °C
0.6 °C
0.8 °C
0.6 °C
0.6 °C
0.5 °C
Isolation
1500 V
1500 V
1500 V
Power Requirements
5.00 to 5.20 VDC @ 190 mA
Operating Temperature
-20 °C to 70 °C
-20 °C to 70 °C
-20 °C to 70 °C
Storage Temperature
-40 °C to 85 °C
-40 °C to 85 °C
-40 °C to 85 °C
Humidity
5-95%, non-condensing
Wire size
22 to 14 AWG
22 to 14 AWG
22 to 14 AWG
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
CE, RoHS, DFARS; UKCA
UL, CE, RoHS, DFARS; UKCA
CE, RoHS, DFARS:UkCA
Lifetime
Lifetime
Lifetime
SNAP PAC System Product Guide
SNAP Analog Input Modules Data Sheet
SNAP I/O analog input modules are part of Opto 22's SNAP PAC System. This document includes descriptions, specifications, and wiring and dimensional diagrams for the following analog input modules:
For analog modules with channel-to-channel isolation, see Form 1182, the SNAP Isolated Analog Input Modules Data Sheet.
Opto 22 Adds New RTD Temperature Sensing I/O Module
I/O Solutions for Temperature Monitoring (Chinese)
This white paper describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
Primer: I/O Solutions for Temperature Monitoring
This primer describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
Scaling and Linearization Example
A example strategy written in PAC Control Basic R8.2f that demonstrates how to scale and linearize values. This example strategy uses subroutines to perform most calculations.
Video: I/O Solutions for Temperature Monitoring
A quick overview on I/O Solutions for temperature monitoring.
