SNAP-AIRTD-8U
SNAP-AIRTD-8U
$734.00 (USA and Canada only)
SNAP 8-Ch Multifunction RTD/Resistance Analog Temperature Input Module
The SNAP-AIRTD-8U analog input module provides 8 input channels, each individually software configurable. This module is commonly used for 3-wire RTD temperature inputs but is also suited to high-resolution resistance measurements. It features open circuit detection if any wire breaks.
You can individually configure each of the module's 8 points for a variety of behaviors, including a fixed temperature range for nickel, platinum, or copper RTD inputs; a fixed range in ohms; or two types of auto-ranging where the module scrolls within a range (in ohms) and chooses the best resolution.
The SNAP-AIRTD-8U has a plug-in terminal on top with spring-clamp connectors for easy wiring. An insertion tool is provided in the box with the module.
All 8 inputs share the same reference terminal. Make sure you use isolated RTD probes.
The SNAP-AIRTD-8U requires a SNAP PAC brain or R-series controller with firmware R9.5a or higher. The module cannot be used with legacy brains or controllers.
SNAP-AIRTD-8U
3-wire RTD input and maximum temperature table range (actual range depends on your probe)
1000 ohm platinum @ 0 °C α= 0.00385
Range: -200 to 850 °C
(-328 to 1,582 °F)
100 ohm platinum @ 0 °C
α= 0.00385
Range: -200 °C to 850 °C
(-328 to 1,582 °F)
10 ohm copper @ 25 °C
α= 0.00427
Range: -60 to 355 °C
(-76 to 671 °F)
1000 ohm nickel @ 0 °C
α= 0.00618
Range: -60 to 170 °C
(-76 to 356 °F)
100 ohm nickel @ 0 °C
α= 0.00618
Range: -60 to 250 °C
(-76 to 482 °F)
1000 ohm nickel @ 70 °F
α= 0.00637
Range: -46 to 148.9 °C
(-50 to 300 °F)
120 ohm nickel @ 0 °C
α= 0.00672
Range: -80 to 260 °C
(-112 to 500 °F)
Input Range
0 to 4000 ohms
0 to 400 ohms
0 to 40 ohms
Accuracy
 From factory
 After setting gain and offset
0.8 °C (Pt); 0.6 °C (Ni)
0.6 °C (Pt); 0.4 °C (Ni)
1.7 °C
1.2 °C
Excitation Current
0.325 mA
2 mA
4.28 mA
Over-Range Limit
10% overrange for all measurements in ohms
Resolution
 In Ohms
 In RTD Temperature
The greater of: (Ohms Range / 100,000) or 1 milliohm
Better than or equal to 0.05 °C (0.09 °F)
Input Filtering
 Front end filtering
 DSP Notch filter
-15 dB @ 50 Hz, -20 dB @ 60 Hz
20 Hz (-3 DdB = 5.24 Hz)
Data Freshness (Max)
1.2 s
Auto-range Settle Time
 Step change from 10 to 8000
 Step change from 8000 to 10
1.2 s to the next higher or lower range
<= 10 s ranging up (channel may show overrange until settled)
<= 10 s ranging down (channel will give a reading while settling)
Total Lead Resistance
200 ohms maximum
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB at 60 Hz
Maximum Survivable Fault Voltage at Input (between any 2 field wires)
±8 V
250 V field terminal to logic connector
Isolation
1500 V field side to logic side
Power Requirements
5.00 to 5.20 VDC @ 135 mA
Operating Temperature
-20 °C to 70 °C
Storage Temperature
-40 °C to 85 °C
Humidity
5-95%, non-condensing
Maximum wire size
20 AWG
Torque, hold-down screws
UL, CE, RoHS, DFARS; UKCA
Lifetime
SNAP Analog Input Modules Data Sheet
SNAP I/O analog input modules are part of Opto 22's SNAP PAC System. This document includes descriptions, specifications, and wiring and dimensional diagrams for the following analog input modules:
For analog modules with channel-to-channel isolation, see Form 1182, the SNAP Isolated Analog Input Modules Data Sheet.
CAD Drawing: SNAP-AIRTD-8U
This CAD file includes the drawing of the SNAP-AIRTD-8U module. Each module provides channel-to-channel isolation.
Video: Spring Clamps - Quick Tip
A quick tip on spring clamps.
