SNAP-AITM-i
SNAP-AITM-i
$393.00 (USA and Canada only)
SNAP 2-Ch Isolated Type E,J, or K Thermocouple Analog Input Module
The SNAP-AITM-i provides two isolated channels of analog-to-digital conversion. Each channel can be configured for -150 to +150 mV DC, or -75 to +75 mV DC, or for type E, J, or K thermocouple operation.
In addition to having two channels isolated from each other, the module is also transformer isolated and optically isolated from other modules and devices.
For a similar module with 4 channels, see the SNAP-AITM-4i If you do not need channel-to-channel isolation, see SNAP-AITM or SNAP-AITM-8.
Input Range
From -150 mV to +150 mV
From -75 mV to +75 mV
Maximum Over Range
± 10%
(= ± 27500 counts)
Resolution
6 µV from -150 mV to +150 mV
3 µV from -75 mV to +75 mV
Cold Junction Temperature Compensation
Automatic when used with SNAP brains
Input Filtering
-3 dB @ 7 Hz
Input Response Time
(% of span/delta V/delta time)
63.2%/95 mV/23 mS
Data Freshness
65 ms for +/- 150 mV
130 ms for +/- 75 mV
130 ms for E-, J-, and K-type thermo­couples
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB @ 60 Hz
Maximum Survivable Input
±15 volts
Maximum Operating
Common Mode Voltage
250 V
Accuracy
0.06% (90 µV) @ 150 mV (full scale)
0.1% (75 µV) @ 75 mV (full scale)
Drift: Gain Temperature
Coefficient
5 µV / °C
Drift: Offset Temperature Coefficient
2 µV / °C
Thermocouple Accuracy [°C]
  From factory
  After user gain and offset commands
± 2.0 (E, J, and K)
± 0.8
Isolation: Optical
4000 V
Isolation: Transformer
1500 V
Isolation: Channel to Chan­nel
250 V continuous
(1500 V transient)
Power Requirements
5 VDC (±0.15) @ 200 mA
Input Resistance
100 megohms (each channel)
Ambient Temperature:
  Storage
-20 °C to 70 °C
-40 °C to 85 °C
Humidity
5-95%, non-condensing
Torque, hold-down screws
Torque, connector screws
3 in-lb (0.34 N-m)
Wire size range
22 to 14 AWG
CE, RoHS, DFARS; UKCA
Lifetime
SNAP PAC System Product Guide
SNAP Isolated Analog Input Modules Data Sheet
The isolated analog input modules described in this document are part of Opto 22's SNAP PAC System. They provide optical isolation, transformer isolation, and channel-to-channel isolation. This data sheet covers the following part numbers:
I/O Solutions for Temperature Monitoring (Chinese)
This white paper describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
Primer: I/O Solutions for Temperature Monitoring
This primer describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
CAD Drawing: SNAP I/O Module
Video: Securing SNAP Module
Video: Removing a SNAP Module
Video: I/O Solutions for Temperature Monitoring
A quick overview on I/O Solutions for temperature monitoring.
Accuracy vs Resolution
