SNAP-D8MC
SNAP-D8MC
$160.00 (USA and Canada only)
SNAP D-Series 8-module Rack With Extra Terminal Block
SNAP D-Series 8-module Rack With Extra Terminal Block For Field Wiring
SNAP D Series (with Auxiliary Terminal Strip)
SNAP-
D4MC
SNAP-
D4MC-P
SNAP-
D6MC
SNAP-
D6MC-P
SNAP-
D8MC
SNAP-
D8MC-P
SNAP-
D12MC
SNAP-
D12MC-P
Description
4-module rack with extra terminal block for field wiring
4-module rack rack with extra terminal block for field wiring, pluggable
6-module rack with extra terminal block for field wiring
6-module rack with extra terminal block for field wiring, pluggable
8-module rack with extra terminal block for field wiring
8-module rack with extra terminal block for field wiring, pluggable
12-module rack with extra terminal block for field wiring
12-module rack with extra terminal block for field wiring, pluggable
Power
Requirements
5 VDC ± 0.1 VDC
@ 200mA max.
(700mA with brain board)
5 VDC ± 0.1 VDC
@ 200mA max.
5 VDC ± 0.1 VDC
@ 300mA max.
5 VDC ± 0.1 VDC
@ 300mA max.
5 VDC ± 0.1 VDC
@ 400mA max.
5 VDC ± 0.1 VDC
@ 400mA max.
5 VDC ± 0.1 VDC
@ 1200mA max.
5 VDC ± 0.1 VDC
@ 1200mA max.
Temperature
Range
0 to 70 °C
0 to 70 °C
0 to 70 °C
0 to 70 °C
0 to 70 °C
0 to 70 °C
0 to 70 °C
0 to 70 °C
Relative
Humidity
95%, non-condensing
95%, non-condensing
95%, non-condensing
95%, non-condensing
95%, non-condensing
95%, non-condensing
95%, non-condensing
95%, non-condensing
Lenght (inches)
4.19
4.19
5.74
5.74
7.74
7.74
10.74
10.74
Length (mm)
106.43
106.43
145.8
145.8
196.6
196.6
272.8
272.8
Center to
Center Length
1.98”
1.98”
3.53”
3.53”
5.53”
5.53”
4.26”
4.26”
# of Center
Postions
2
2
2
2
2
2
3
3
Agency Approvals UL, CE, RoHS, DFARS; UKCA UL, CE, RoHS, DFARS; UKCA UL, CE, RoHS, DFARS; UKCA UL, CE, RoHS, DFARS; UKCA UL, DFARS UL, DFARS UL, CE, RoHS, DFARS; UKCA UL, CE, RoHS, DFARS; UKCA
SNAP D Series Racks (with Terminal Strip) Data Sheet
The SNAP I/O D Series racks are designed for discrete control applications and can accommodate 4, 6, 8, or 12 SNAP 4-channel digital modules. These MC and MC-P model racks provide a screw-type terminal strip for additional wiring requirements. This data sheet applies to these parts:
