$185.00 (USA and Canada only)
Feature
SNAP-HD-ACF6
SNAP-HD-CBF6
SNAP-HD-BF6
Cable length
6 feet (1.8 meters)
Connectors
Two-cable assembly; 16-pin connector at module end; flying leads at other end
One 40-pin connector at module end; flying leads at other end
One connector at module end; one connector at breakout board end
Wires
Pre-stripped, color-coded, 22-gauge wires
Pre-stripped, color-coded, 24-gauge wires
24 gauge wires
Use with
Modules: SNAP-IAC-16 SNAP-IAC-A-16 SNAP-IAC-K-16 SNAP-IDC-16 SNAP-IDC-HT-16
Modules: SNAP-IDC-32
SNAP-IDC-32-FM
SNAP-IDC-32N
SNAP-ODC-32-SNK
SNAP-ODC-32-SNK-FM
SNAP-ODC-32-SRC
SNAP-ODC-32-SRC-FM
SNAP-AIV-32
SNAP-AIV-32-FM
Modules to breakout boards (regular and -FM versions of all): SNAP-IDC-32 to SNAP-IDC-HDB
SNAP-IDC-32N to SNAP-IDC-HDB SNAP-ODC-32-SNK to SNAP-ODC-HDB SNAP-ODC-32-SRC to SNAP-ODC-HDB SNAP-AIV-32 to SNAP-AIV-HDB SNAP-AIMA-32 to SNAP-AIMA-HDB
CE, RoHS, DFARS
30 months
SNAP TEX cables and breakout boards are part of the SNAP TEX family of wiring and mounting accessories. These parts save time and expense during installation, maintenance, and debugging by reducing the time and effort required to wire field devices to SNAP I/O modules. This data sheet covers the following part numbers:
SNAP I/O high-density digital modules from Opto 22 provide 16 or 32 digital input or output points in one compact SNAP module. These modules are ideal for OEMs and others who have high point-count applications, or for anyone requiring more than 64 digital points on a single SNAP PAC rack. The high-density configuration reduces per-point costs of digital I/O systems by providing up to eight times as many I/O points in the same space. SNAP high-density digital modules are part of the SNAP PAC System. They can also be used as part of intelligent remote I/O with an Allen-Bradley Logix PLC system. HDD modules require a SNAP PAC R-series controller or a SNAP PAC brain for I/O processing. This data sheet covers the following modules:
This guide covers how to install and test SNAP 16-channel and 32-channel digital modules, part of the SNAP PAC System. These modules provide 16 or 32 points of digital input or digital output in the same space as a 4-channel digital module. They are ideal for OEMs and for anyone who needs up to 512 digital points on a single mounting rack. SNAP high-density digital modules include the following part numbers:
A quick overview of SNAP TEX wiring and mounting accessories.
$278.00
$452.00
$411.00
$1,418.00
$1,381.00
$1,195.00
$1,295.00
$451.00
