SNAP-IAC5FM
SNAP-IAC5FM
OBSOLETE SNAP 4-Ch 90-140 VAC/VDC Digital (Discrete) Input Module
Please call Pre-Sales Engineering  for more information or see Form 2411, Obsolete SNAP 4-Channel Digital I/O Technical Note
The SNAP-IAC5FM provides four channels of 90-140 VAC/VDC digital input. Each channel senses the on/off status for AC (or DC) voltages from sources such as proximity switches, push buttons, or auxiliary contacts. It has removable top-mounted connectors for easy access to field wiring, as well as channel-specific LEDs for convenient troubleshooting.
SNAP-IAC5FM [Obsolete]
SNAP-IAC5AFM
[Obsolete]
SNAP-IDC5FM
[Obsolete]
SNAP-IDC5DFM
[Obsolete]
Wire size
22 to 14 AWG
22 to 14 AWG
22 to 14 AWG
22 to 14 AWG
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Nominal Input Voltage
120 VAC/VDC
240 VAC/ VDC
24 VAC/VDC
5 VDC
Channel-to-channel
isolation
300 VAC
(1,500 V transient)
300 VAC
(1,500 V transient)
300 VAC
(1,500 V transient)
300 VAC
(1,500 V transient)
Input Voltage Range
90–140 VAC/VDC
180–280 VAC/VDC
10–32 VAC/VDC
2.5–28 VDC
Turn-on Voltage
90 VAC/VDC
180 VAC/VDC
10 VAC/VDC
2.5 VDC
Turn-off Voltage
35 VAC/VDC
35 VAC/VDC
3 VAC/VDC
1 VDC
Input Resistance
169 K ohms (nominal)
305 K ohms (nominal)
15 K ohms (nominal)
3 K ohms (nominal)
Logic Side Ratings
Logic Output Voltage
<.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 400 mA sourcing
<.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 400 mA sourcing
<.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 0.4 mA sourcing
<.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 0.4 mA sourcing
Logic Supply Voltage*
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
Logic Supply Current
50 mA maximum
50 mA maximum
50 mA maximum
50 mA maximum
Negative True Logic
Output Drive
TTL 74 Series=1 UL
TTL 74LS Series=5 UL
TTL 74 Series=1 UL
TTL 74 Series=1 UL
TTL 74 Series=1 UL
Module Ratings
Number of Channels
Per Module
4
4
4
4
Turn-on Time
30 msec
30 msec
5 msec
1 msec
Turn-off Time
30 msec
30 msec
15 msec
1 msec
Optical Isolation
(Field Side to
Logic Side)
4,000 volts (transient)
Temperature
-20 to 70 °C, operating
-40 to 85 °C, storage
CE, RoHS, DFARS; UKCA
Lifetime
Lifetime
Lifetime
Lifetime
*When used with an I/O processor (brain or on-the-rack controller), the processor requires 5.0 to 5.2 VDC.
This technical note contains information you may need about OBSOLETE SNAP 4-Channel Digital I/O modules you’re still using. Included are part numbers, descriptions, specifications, wiring diagrams, and dimensional drawings. These parts have been removed from data sheets because we no longer sell them.
This document includes information on the following obsolete types of SNAP 4-channel digital I/O modules:
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
