SNAP-IDC5D
SNAP-IDC5D
$67.25 (USA and Canada only)
SNAP 4-Ch 2.5-28 VDC Digital (Discrete) Input Module
The SNAP-IDC5D provides four channels of 2.5-28 VDC digital input. Each channel senses the on/off status for DC voltages from sources such as proximity switches, push buttons, or auxiliary contacts. The module has removable top-mounted connectors for easy access to field wiring, as well as channel-specific LEDs for convenient troubleshooting.
SNAP-IDC5
SNAP-IDC5D
SNAP-IDC5G
SNAP-IDC5-HT
Key Feature
Leakage-tolerant
Wire size
22 to 14 AWG
22 to 14 AWG
22 to 14 AWG
22 to 14 AWG
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Nominal Input Voltage
24 VAC/VDC
5 VDC
48 VAC/VDC
24 VAC/VDC
Channel-to-channel isola­tion
300 VAC
(1,500 V transient)
300 VAC
(1,500 V transient)
300 VAC
(1,500 V transient)
300 VAC
(1,500 V transient)
Input Voltage Range
10–32 VAC/VDC
2.5–28 VDC
35–75 VAC/VDC
15–32 VAC/VDC
Turn-on Voltage
10 VAC/VDC
2.5 VDC
35 VAC/VDC
15 VAC/VDC
Turn-off Voltage
3 VAC/VDC
1 VDC
7 VAC/VDC
8 VAC/VDC
Input Resistance
15 K ohms (nominal)
3 K ohms (nominal)
64 K ohms (nominal)
3 K ohms (nominal)
Logic Side Ratings
Logic Output Voltage
<.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 0.4 mA sourcing
<.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 0.4 mA sourcing
<.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 0.4 mA sourcing
<.5 V max. (on)
@ 2 mA sinking
2.7 V min. (off)
@ 0.4 mA sourcing
Logic Supply Voltage***
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
Logic Supply Current
50 mA maximum
50 mA maximum
50 mA maximum
50 mA maximum
Negative True Logic Out­put Drive
TTL 74 Series = 1 UL
TTL 74LS Series = 5 UL
Module Ratings
Number of Channels Per Module
4
4
4
4
Turn-on Time
5 msec
1 msec
5 msec
20 msec
Turn-off Time
15 msec
1 msec
15 msec
25 msec
Optical Isolation
(Field Side to Logic Side)
4,000 volts (transient)
Temperature
-20 °C to 70 °C, operating
-40 °C to 85 °C, storage
UL, CE, CSA, RoHS, DFARS, NEBS; UKCA
UL, CE, CSA, RoHS, DFARS; UKCA
UL, CE, RoHS, DFARS; UKCA
Lifetime
Lifetime
Lifetime
Lifetime
* At 20kHz, 5Vp-p square wave input, 50% duty cycle.
** At 20kHz, 28Vp-p square wave input, 50% duty cycle.
*** When used with an I/O processor (brain or on-the-rack controller), the processor requires 5.0 to 5.2 VDC.
SNAP PAC System Product Guide
SNAP Digital Input Modules Data Sheet
SNAP digital input modules are designed to work with SNAP PAC racks and can sense either AC or DC signals.
All SNAP digital input modules are compatible with SNAP PAC brains and R-series controllers, including Wired+Wireless models.
Most digital input modules are also compatible with SNAP D-series or legacy M-series and B-series racks and with the brains that mount on them.
This data sheet applies to:
CAD 3D Drawing: SNAP-IDC5D Digital Input Module
This CAD file contains a 3-dimensional drawing of the SNAP-IDC5D digital input module, which provides four channels of 2.5-28 VDC digital input.
CAD Drawing: SNAP I/O Module
Video: Securing SNAP Module
Video: Removing a SNAP Module
Video: Automation 101: Wire a Proximity Sensor
Learn how you can wire a proximity sensors to gather machine data without ever touching equipment and without interfering in your process.
Accuracy vs Resolution
