SNAP-OAC5
SNAP-OAC5
$96.75 (USA and Canada only)
SNAP 4-Ch 12-250 VAC Digital (Discrete) Output Module
The SNAP-OAC5 provides four channels of 12-250 VAC digital output, each switching a separate AC load. AC outputs use zero voltage turn on and zero current turn off for transient-free switching. The module has removable top-mounted connectors to provide easy access to field wiring and features channel-specific LEDs for troubleshooting.
For a similar module with isolated channels, see SNAP-OAC5-I.
For easier, faster wiring, see SNAP TEX cables and breakout boards.
SNAP-OAC5
SNAP-OAC5MA
SNAP-OAC5-i
Key Feature
Diagnostic switches
Four isolated channels
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Line Voltage - Range
12–250 VAC
12–250 VAC
12–250 VAC
Line Voltage - Nominal
120/240 VAC
120/240 VAC
120/240 VAC
Current Rating
0 °C to 70 °C Ambient
3 amps per module
3 amps per module
3 amps per module
One Cycle Surge
80 amps peak (50/60 Hz)
Minimum Load Current
20 mA
20 mA
20 mA
Output Voltage Drop
1.6 volts max.@ 0.75 amps
Off-state Leakage at
Nominal Voltage - 60 Hz
2.5 mA @ 240 VAC
1.25 mA @ 120 VAC
2.5 mA @ 240 VAC
1.25 mA @ 120 VAC
2.5 mA @ 240 VAC
1.25 mA @ 120 VAC
Peak Blocking Voltage
500 V
500 V
500 V
Operating Frequency
25–65 Hz
25–65 Hz
25–65 Hz
dV/ dt - Off-state
200 volts/msec
200 volts/msec
200 volts/msec
dV/ dt - Commutating
Fuse
(Common to all Channels)
250 VAC - 4A 5x20 mm
Fast-acting Bell Fuse Part: BEL 5HF4
Opto 22 Part: SNAP-FUSE4AB
Has four isolated channels.
User must provide own fus­ing.
Channel-to-channel isolation
Not applicable
300 VAC
(1500 V transient)
300 VAC
(1500 V transient)
Logic Side Ratings
Pickup Voltage
4 V @ 5.5 mA
4 V @ 5.5 mA
4 V @ 5.5 mA
Dropout Voltage
1 VDC
1 VDC
1 VDC
Control Resistance
220 ohms
220 ohms
220 ohms
Logic Supply Voltage
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
Logic Supply Current
50 mA maximum
50 mA maximum
50 mA maximum
Module Ratings
Number of Channels Per Module
4
4
4
Turn-on Time
0.5 cycle maximum
(zero volts crossover)
0.5 cycle maximum
0.5 cycle maximum
Turn-off Time
0.5 cycle maximum
(zero current crossover)
0.5 cycle maximum
0.5 cycle maximum
Isolation (Field Side to Logic Side)
4,000 volts (transient)
Temperature
-20 ° to 70 °C, operating
-40 ° to 85 °C, storage
Wire size range
22 to 14 AWG
22 to 14 AWG
22 to 14 AWG
UL, CE, CSA, RoHS, DFARS; UKCA
UL, CE, RoHS, DFARS; UKCA
Lifetime
30 months
Lifetime
SNAP PAC System Product Guide
SNAP Digital Output Modules Data Sheet
Opto 22 SNAP digital output modules are designed to mount on SNAP PAC racks and be used with SNAP PAC brains and R-series controllers, both standard wired and Wired+Wireless models. You can choose from AC or DC output modules.
These modules are also compatible with SNAP D-series and legacy M-series and B-series racks, and they can be used with legacy Ethernet-based brains as well as other SNAP brains, such as the serial B3000 or the B3000-HA.
SNAP-OAC5
SNAP-OAC5-I
SNAP-OAC5MA
SNAP-ODC5A-I
SNAP-ODC5ASNK
SNAP-ODC5-I
SNAP-ODC5MA
SNAP-ODC5SNK
SNAP-ODC5SRC
CAD Drawing: SNAP I/O Module
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
