SNAP-OAC5FM
SNAP-OAC5FM
OBSOLETE SNAP 4-Ch 12-250 VAC Digital (Discrete) Output Module
Contact Opto 22 Pre-Sales engineers for more information or see Form 2411, Obsolete SNAP 4-Channel Digital I/O Technical Note
The SNAP-OAC5FM provides four channels of 12-250 VAC digital output, each switching a separate AC load. AC outputs use zero voltage turn on and zero current turn off for transient-free switching.
SNAP-OAC5-FM
[Obsolete]
SNAP-OAC5-i-FM
[Obsolete]
Key Feature
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Line Voltage - Range
12–250 VAC
12–250 VAC
Line Voltage - Nominal
120/240 VAC
120/240 VAC
Current Rating
0 °C to 70 °C Ambient
3 amps per module
3 amps per module
One Cycle Surge
80 amps peak (50/60 Hz)
Minimum Load Current
20 mA
20 mA
Output Voltage Drop
1.6 volts max.@ 0.75 amps
Off-state Leakage at Nominal Voltage - 60 Hz
2.5 mA @ 240 VAC
1.25 mA @ 120 VAC
2.5 mA @ 240 VAC
1.25 mA @ 120 VAC
Peak Blocking Voltage
500 V
500 V
Operating Frequency
25–65 Hz
25–65 Hz
dV/ dt - Off-state
200 volts/msec
200 volts/msec
dV/ dt - Commutating
Snubbed for rated 0.5 power
factor load
Fuse
(Common to all Channels)
250 VAC - 4A 5x20 mm
Fast-acting Bell Fuse Part No. BEL 5HF4
Opto 22 Part No. SNAP-FUSE4AB
Has four isolated channels.
User must provide own fusing.
Channel-to-channel isolation
Not applicable
300 VAC
(1500 V transient)
Logic Side Ratings
Pickup Voltage
4 V @ 5.5 mA
4 V @ 5.5 mA
Dropout Voltage
1 VDC
1 VDC
Control Resistance
220 ohms
220 ohms
Logic Supply Voltage
5 VDC ± 0.25 VDC
5 VDC ± 0.25 VDC
Logic Supply Current
50 mA maximum
50 mA maximum
Module Ratings
Channels Per Module
4
4
Turn-on Time
0.5 cycle maximum
(zero volts crossover)
0.5 cycle maximum
Turn-off Time
0.5 cycle maximum
(zero current crossover)
0.5 cycle maximum
Isolation (Field Side to Logic Side)
4,000 volts (transient)
Temperature
-20 ° to 70 °C, operating
-40 ° to 85 °C, storage
Wire size range
22 to 14 AWG
22 to 14 AWG
CE, RoHS, DFARS; UKCA
Lifetime
Lifetime
This technical note contains information you may need about OBSOLETE SNAP 4-Channel Digital I/O modules you’re still using. Included are part numbers, descriptions, specifications, wiring diagrams, and dimensional drawings. These parts have been removed from data sheets because we no longer sell them.
This document includes information on the following obsolete types of SNAP 4-channel digital I/O modules:
CAD Drawing: SNAP I/O Module
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
