SNAP-ODC-32-SNK
SNAP-ODC-32-SNK
$411.00 (USA and Canada only)
SNAP 32-channel Digital (Discrete) Output Module, 5-60 VDC Load Sinking
The SNAP-ODC-32-SNK digital output module (load sinking) provides 32 digital output channels in one compact SNAP module. This module is ideal for OEMs and others with applications with high point counts, or for those requiring a large number of digital output channels on one SNAP I/O rack. The high-density configuration reduces per-point costs of digital I/O systems by providing up to eight times as many I/O channels in the same space.
If you're unsure whether you need a sinking or sourcing module, see the sinking/sourcing demo or watch the brief Sinking vs. Sourcing video.
For easy field wiring, use the SNAP-ODC-HDB or compact SNAP-UDC-HDB breakout rack and the SNAP-HD-BF6 header cable. A wiring harness with flying leads (SNAP-HD-CBF6) is also available.
For switching signals with higher current, see the SNAP-UDC-HDB-G4 breakout board, which mounts G4 input modules that handle up to 3 amps per point (G4 modules are sold separately).
Reference Charts: Build your system in the SNAP I/O Configurator.
SNAP-ODC-32-SRC
SNAP-ODC-32-SRC-FM [Obsolete]
SNAP-ODC-32-SNK
SNAP-ODC-32-SNK-FM [Obsolete]
Switching Voltage
5–60 VDC
5–60 VDC
Nominal Switching Voltage
12–24 VDC
12–24 VDC
Logic Voltage and Current
5 VDC ± 0.1 @ 150 mA
Maximum Off State Voltage
60 VDC
60 VDC
Output Leakage, Typical
<10 microamps per channel (60 V, 70 °C)
Maximum Load per Point
0.25 A
0.25 A
Voltage Drop
0.15 VDC @ 0.25 A
0.15 VDC @ 0.25 A
Surge (1 sec.)
1 A
1 A
Output Arrangement
32 output channels; 4 groups of 8 outputs each. Points in each group share a common positive connection.
32 output channels; 4 groups of 8 outputs each. Points in each group share a common negative connection.
Maximum Operating
Common Mode Voltage
250 V
250 V
Isolation: Field to Logic
1500 V
1500 V
Output Turn-On/Off Time
100 microseconds
100 microseconds
Polling time from I/O proces­sor to module1
2–30 ms typical2
2–30 ms typical2
Indicators
None; use optional OptoTerminal-G20 diag­nostic display or breakout rack.
None; use optional OptoTerminal-G20 diagnostic display or breakout rack.
Maximum Number of HDD Modules on One Mounting Rack
16
16
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Operating Temperature
-20 to 70 °C
-20 to 70 °C
Storage Temperature
-40 to 85 °C
-40 to 85 °C
CE, RoHS, DFARS; UKCA
Lifetime
Lifetime
1 Affects turn-on and turn-off determination
2 Time varies based on the SNAP PAC I/O processor (brain or on-the-rack controller), processor configuration, and Ethernet host communication activity.
Modules, Cables, and Breakout Boards Compatibility Charts
This document shows which SNAP I/O modules, breakout boards, and cables can be used together.
Comparison Chart: SNAP 4-Channel and High-Density Digital Modules
This document compares 4-channel and high-density SNAP digital I/O modules.
SNAP PAC System Product Guide
SNAP High-Density Digital Modules Data Sheet
SNAP I/O high-density digital modules from Opto 22 provide 16 or 32 digital input or output points in one compact SNAP module. These modules are ideal for OEMs and others who have high point-count applications, or for anyone requiring more than 64 digital points on a single SNAP PAC rack. The high-density configuration reduces per-point costs of digital I/O systems by providing up to eight times as many I/O points in the same space.
SNAP high-density digital modules are part of the SNAP PAC System. They can also be used as part of intelligent remote I/O with an Allen-Bradley Logix PLC system. HDD modules require a SNAP PAC R-series controller or a SNAP PAC brain for I/O processing.
This data sheet covers the following modules:
The data sheet also covers the following accessories used with SNAP HDD modules:
SNAP High-Density Digital Module User's Guide
This guide covers how to install and test SNAP 16-channel and 32-channel digital modules, part of the SNAP PAC System. These modules provide 16 or 32 points of digital input or digital output in the same space as a 4-channel digital module. They are ideal for OEMs and for anyone who needs up to 512 digital points on a single mounting rack. SNAP high-density digital modules include the following part numbers:
  • SNAP-IAC-16
  • SNAP-IAC-A-16
  • SNAP-IAC-K-16
  • SNAP-IDC-16
  • SNAP-IDC-32
  • SNAP-IDC-32D
  • SNAP-IDC-32DN
  • SNAP-IDC-32-FM [OBSOLETE]
  • SNAP-IDC-32N
  • SNAP-ODC-32-SNK
  • SNAP-ODC-32-SNK-FM  [OBSOLETE]
  • SNAP-ODC-32-SRC
  • SNAP-ODC-32-SRC-FM  [OBSOLETE]
Case Study: AAQUA NV
Antwerp-based AAQUA NV has specialized in engineering and constructing industrial wastewater treatment plants since 1999, with customers all over the world. Where possible, the company also adds value to customer waste, either by recycling wastewater to drinking water quality or by capturing the energy in the water to reduce fuel costs.
Initially AAQUA often worked with a subcontractor to automate treatment, but in 2005 they began offering automation themselves. To do so, the small company needed an automation system that was Ethernet based, flexible, reliable, offered remote access, and was easy to learn.
In this case study, read how they found that system and how they use it today.
Sinking or Sourcing Technical Note
Are you confused about sinking and sourcing when wiring DC circuits? This technical note explains what sinking and sourcing mean, explores where you would use one wiring method rather than the other, and shows how to use a digital output module with your DC circuit.
Using ioDisplay 6.0 with SNAP High-Density Digital Modules Technical Note
This technical note is for customers using SNAP high-density digital modules with ioControl 6.1 and ioDisplay 6.0.
CAD 3D Drawing: SNAP-ODC-32-SRC Digital Output Module
This CAD file contains a 3-dimensional drawing of the SNAP-ODC-32 32-channel digital input and output modules. The drawing applies to the following modules:
CAD Drawing: SNAP-ODC-HDB Breakout Rack
This is a CAD drawing of the SNAP-ODC-HDB breakout rack, which is used with two SNAP high-density digital output modules: SNAP-ODC-32-SNK and SNAP-ODC-32-SRC.
Optomation Systems ioControl Functions
A piecewise linear interpolator function PLI under ioControl 5.1. The ioScript version can be easily copied to your program. It can be used for any of the following applications:
  • Calculating volume from tank level measurement (PV=Level Q=Volume)
  • Setpoint Generator (PV=Elapsed Time Q=Required Setpoint, eg Temp or Flow)
  • Flow rate profiling (PV=Dif Pressure Q=Flow Rate)
  • Split Range Control (PV=Common Output Q=Valve1 profile)
  • Adaptive Gain (PV=Secondary Variable Q=PID Gain Value)
PPP sample code and configuration for ioControl
The zip file contains sample ioControl code for the SNAP Ultimate I/O and SNAP-LCE. The code demonstrates how these controllers can exchange information via PPP and modems. A document is included to explain the samples.
This file contains sample code.
Note: Before you download, read the Legal Agreement.
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
Sinking vs Sourcing
Switching a DC circuit? Learn about sinking and sourcing, and the digital output modules to use with each.
