SNAP-PAC-RCK12-FM
SNAP-PAC-RCK12-FM
OBSOLETE SNAP PAC 12-Module Mounting Rack
Please consider SNAP-PAC-RCK12 or contact Opto 22 Pre-Sales engineers for more information.
The SNAP-PAC-RCK12-FM mounts one SNAP PAC brain or on-the-rack controller and up to 12 analog, digital, serial, and special-purpose SNAP I/O modules. The SNAP-PAC-RCK12-FM can be DIN-rail or panel mounted.
This rack works with all SNAP I/O modules on the Opto 22 website. Analog, digital, and serial modules can be mixed on the rack and placed in any position. (Some serial modules are limited to a maximum of eight on one rack. See module data sheets for limitations and power requirements.)
Together with I/O modules and a brain or rack-mounted controller, this rack forms an I/O unit that provides distributed control in a SNAP PAC System. The I/O unit can also be used for PC-based control or as intelligent remote I/O for  an Allen-Bradley MicroLogix PLC or other RSLogix-based system, such as ControlLogix or CompactLogix.
Other SNAP PAC racks available: Build your system in the SNAP I/O Configurator.
Power1 Requirements
5.0 to 5.2 VDC @ 4.2 Amps max
I/O Processor2
Compatibility
SNAP-PAC-EB1
SNAP-PAC-EB2
SNAP-PAC-R1-W [Obsolete]
SNAP-PAC-R2-W [Obsolete]
SNAP-PAC-EB1-W [Obsolete]
SNAP-PAC-EB2-W [Obsolete]
SNAP-PAC-R1-FM [Obsolete]
SNAP-PAC-R2-FM [Obsolete]
SNAP-PAC-EB1-FM [Obsolete]
SNAP-PAC-EB2-FM [Obsolete]
Replacement Fuse
SNAP-FUSE7.5AB or Littelfuse 297 07.5
Rack Power Terminals Wire Size
22 to 14 AWG
Operating Temperature
–20 to 70 °C
Storage Temperature
–40 to 85 °C
Relative Humidity
95%, non-condensing
CE, ATEX, RoHS, DFARS; UKCA
1 Power requirements shown are for a rack, a processor, and a full load of analog modules. Power requirements for SNAP serial and high-density modules are higher. See module data sheets.
2 “I/O Processor” means a SNAP PAC brain or SNAP PAC on-the-rack controller. For compatibility with legacy Opto 22 products, see form #1693, Legacy and Current Product Comparison and Compatibility Charts.
Obsolete SNAP PAC Rack Technical Note
This technical note contains information you may need about obsolete SNAP PAC racks you’re still using.
Included are part numbers, descriptions, specifications, wiring diagrams, and dimensional drawings. In most
cases, these parts have been removed from data sheets because we no longer sell them.
This document includes information on the following obsolete SNAP PAC racks:
CE Declaration of Conformity: ATEX
CAD 3D Drawing: SNAP-PAC-RCK12 Mounting Rack
This CAD file contains a 3-dimensional drawing of the SNAP-PAC-RCK12 mounting rack, which holds a SNAP PAC I/O processor (brain or rack-mounted controller) plus up to 12 analog, digital, and serial I/O modules.
CAD Drawing: Base for SNAP-PAC-RCK12
This CAD file includes a drawing of the base for the SNAP-PAC-RCK12, a mounting rack that holds one SNAP PAC brain or on-the-rack controller plus any mix of up to 12 analog, digital, and serial SNAP I/O modules.
CAD Drawing: SNAP-PAC-RCK12 Mounting Rack
This CAD file includes drawings of the SNAP-PAC-RCK12 mounting rack, which holds one SNAP PAC brain or on-the-rack controller plus up to 12 analog, digital, and serial SNAP I/O modules.
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
