SNAP-RACKDIN
SNAP-RACKDIN
$13.00 (USA and Canada only)
SNAP Rack DIN-rail Adapter Clip
The SNAP-RACKDIN provides adapter clips for mounting a SNAP rack on a 35mm DIN rail.
SNAP I/O Racks Data Sheet
SNAP B-series mounting racks are designed to hold an intelligent SNAP I/O processor (either a SNAP brain or an on-the-rack controller) and several I/O modules.
This data sheet includes detailed information and specifications for SNAP B-series racks as well as the digital-only SNAP-D64RS rack. Rack fuses and DIN-rail adapters are also included in the data sheet.
B-series racks are used with serial and some Ethernet I/O processors.
  • With Ethernet processors such as the SNAP-B3000-ENET, B-series racks hold analog, digital, and serial modules.
  • With serial processors such as the serial B3000 brain, they hold analog and digital modules.
This document applies to these parts: NOTE: For racks to use with SNAP PAC brains and rack-mounted controllers, or with SNAP-UP1-M64 and SNAP Simple brains, see Form #1684, the SNAP PAC Racks Data Sheet.
SNAP D Series Racks (with Terminal Strip) Data Sheet
The SNAP I/O D Series racks are designed for discrete control applications and can accommodate 4, 6, 8, or 12 SNAP 4-channel digital modules. These MC and MC-P model racks provide a screw-type terminal strip for additional wiring requirements. This data sheet applies to these parts:
SNAP D Series Racks Data Sheet
The SNAP I/O D Series racks are designed for discrete control applications and can accommodate 4, 6, 8, or 12 SNAP 4-channel digital modules. This data sheet applies to:
Attaching the Adapter Clip to a DIN Rail
This document illustrates how to attach a DIN-rail clip (SNAP-RACKDIN) to a 35mm DIN rail.
DIN-rail clips are used with I/O mounting racks, such as SNAP PAC racks, which hold I/O modules and a brain or rack-mounted controller.
AutoCAD Drawings
