SNAP-UDC-HDB
SNAP-UDC-HDB
$174.00 (USA and Canada only)
Compact breakout rack for SNAP 32-channel digital (discrete) input or output module
The small-footprint SNAP-UDC-HDB breakout board consolidates wiring for a 32-point SNAP high-density digital (HDD) I/O module into a small area.
Its universal design means the SNAP-UDC-HDB can be used with either SNAP 32-point input modules (like the SNAP-IDC-32) or SNAP 32-point output modules (such as the SNAP-ODC-32-SNK or SNAP-ODC-32-SRC).
This breakout board is ideal for tight locations. To save space, it does not provide fuses. Spring-clamp wiring connectors make wiring the board faster and simpler.
Connect the SNAP 32-point module to the board using a SNAP-HD-BF6 cable.
If you need a breakout board with fuses, see the SNAP-IDC-HDB (for inputs) or the SNAP-ODC-HDB (for outputs).
SNAP-UDC-HDB Breakout Rack for High-Density Digital Input and Output Modules
Used with SNAP-IDC-32, SNAP-IDC-32-FM SNAP-IDC-32N, SNAP-IDC-32D, SNAP-IDC-32DN SNAP-ODC-32-SNK, SNAP-ODC-32-SNK-FM SNAP-ODC-32-SRC, SNAP-ODC-32-SRC-FM
Connectors 40-pin header connects to 32-point module using SNAP-HD-BF6 cable.
64 spring-clamp terminal block provides 1 connection for each of 32 channels, 4 connections per 8-channel zone for field common, and 4 connections per 8-channel zone for module common.
Wire size Field connector: 12-28 AWG
Indicators 1 LED status indicator for each point (32 LEDs total)
Jumpers When using any SNAP-IDC-32 input module, install all four jumpers (JP1-JP4) in X positions.
When using any SNAP-ODC-32 output module, install all four jumpers in Z positions.
Voltage 32 VDC maximum, 12–24 VDC nominal
Agency Approvals UL, CE, RoHS, DFARS
Warranty 30 months from date of manufacture
Modules, Cables, and Breakout Boards Compatibility Charts
This document shows which SNAP I/O modules, breakout boards, and cables can be used together.
SNAP TEX Cables and Breakout Boards Data Sheet
SNAP TEX cables and breakout boards are part of the SNAP TEX family of wiring and mounting accessories. These parts save time and expense during installation, maintenance, and debugging by reducing the time and effort required to wire field devices to SNAP I/O modules. This data sheet covers the following part numbers:
CAD Drawing: SNAP-UDC-HDB Breakout Rack
This ZIP file includes drawings in various file formats for the SNAP-UDC-HDB breakout rack.
Video: Spring Clamps - Quick Tip
A quick tip on spring clamps.
