SNAP-UP1-M64
SNAP-UP1-M64
OBSOLETE SNAP Ultimate controller/brain, analog/simple digital/serial, for ioProject systems
**** The SNAP-UP1-M64 is obsolete and no longer available.****
For new designs, the SNAP-PAC-R2 on-the-rack controller has the same features as the SNAP-UP1-M64 but is more powerful.
The SNAP-UP1-M64 controller/brain is a programmable I/O and communications processor. It can be used as a rack-mounted controller or as an I/O unit in a larger control system based on a more powerful Opto 22 controller, such as the SNAP-PAC-S1. The SNAP-UP1-M64 mounts on SNAP PAC racks, such as the SNAP-PAC-RCK16.
Used as a rack-mounted controller, the SNAP-UP1-M64 is programmed using the ioProject Basic software suite, which is included in the purchase price. The newer PAC Project software suite was designed for SNAP PAC controllers but also offers limited support for SNAP Ultimate I/O.
NOTE: Not all SNAP I/O modules are compatible with this controller. See Legacy and Current Product Comparison and Compatibility Charts to determine compatibility.
SNAP-UP1-ADS [Obsolete], SNAP-UP1-D64, and SNAP-UP1-M64 [Obsolete}
Power Requirements
5.0 VDC to 5.2 VDC at 1.2 A maximum (does not include module power requirements)
Processor
32-bit ColdFire 5407
Memory:
  Total RAM
  Battery-backed RAM
  Flash EEPROM
16 MB
512 KB
8 MB
Backup battery
CR2032, fixed (not user replaceable)
Network Interface
IEEE 802.3 network, 10Base-T and 100Base-TX
Serial Port
RS-232
Serial Data Rates
Default is 19,200 baud; baud rate is soft-selectable from 150 to 115,200 baud.
100 meters with Category 5 or superior UTP.
Jumpers (Internal)
Boot to kernel/boot to loader
Reset to factory defaults
Temperature:
  Storage
0 °C to 70 °C
-40 °C to 85 °C
Humidity
SNAP Ultimate Brain Data Sheet
*** NOTE: The SNAP-UP1-ADS and SNAP-UP1-M64 are obsolete and no longer available. The SNAP-UP1-D64 is available until limited stock is depleted. ***
For new development, see groov RIO and groov EPIC.
The SNAP Ultimate brain (SNAP-UP1-ADS, SNAP-UP1-D64, SNAP-UP1-M64) is an I/O and communications processor that mounts on a standard SNAP rack. The brain features 10/100 Mbps Fast Ethernet connectivity, programmability, and built-in enterprise connectivity. The brain is programmed using flowchart-based ioControl programming software, which is included in the purchase price of the SNAP Ultimate brain.
SNAP Ultimate I/O Firmware README
This README file lists revision changes made to the SNAP Ultimate I/O firmware used in SNAP Ultimate brains.
ioProject Readme Notes
SNAP Legacy Firmware README
This README file lists revision changes made to the firmware used in SNAP PAC family controllers before Version 8.0a, the SNAP-LCE controller, and SNAP Ultimate, Ethernet, and Simple brains.
Modbus/TCP Protocol Guide
In addition to groov I/O and the SNAP PAC System, the guide also covers Modbus/TCP communication with older Opto 22 Ethernet-based devices, including SNAP Ethernet, SNAP Simple, and SNAP Ultimate I/O; and E1 and E2 brain boards.
Allen-Bradley DF1 Integration Kit For ioControl Users Guide
The Allen-Bradley DF1 Integration Kit (Part # IOP-INT-ABDF1) provides users of Opto 22’s ioControl software(version 6.0 and above) an easy method of communicating with Allen-Bradley drivers or PLCs using the DF1 protocol. Opto 22 controllers can act as either a “master” or a “slave” device. They can be connected directly to the serial port on an Allen-Bradley PLC or to Data Highway networks using standard Data Highway interface devices.
OptoMMP Protocol Guide
NOTE: This guide replaced previous individual programming guides for SNAP Ultimate I/O (form #1312) and SNAP Ethernet I/O (form #1227). This document was formerly called the "SNAP Ethernet-Based I/O Units Protocols and Programming Guide."
SNAP Ethernet-Based I/O Units User's Guide
*** NOTE: These products are obsolete and no longer available. For new development, we recommend groov RIO and groov EPIC. ***
This guide shows you how to install, use, and troubleshoot I/O units that contain the following brains: SNAP-B3000-ENET, SNAP-ENET-S64, SNAP-UP1-M64, SNAP-UP1-ADS, SNAP-ENET-RTC, SNAP-ENET-D64, and SNAP-UP1-D64.
NOTE: This guide replaces previous individual user's guides for SNAP Ultimate I/O (form #1311) and SNAP Ethernet I/O (form #1112).
ioManager User's Guide
ioManager is the software tool used to assign IP addresses and configure I/O points and system functions on most Opto 22 Ethernet-based hardware, including SNAP-LCE controllers: SNAP Ethernet, SNAP Ultimate, SNAP Simple, E1, and E2 I/O units; and SNAP-IT units. ioManager can also be used to directly read or write to these devices.
ioControl Commands Quick Reference Card
Quick reference card for using ioControl, including all standard ioControl commands and their OptoScript equivalents. ioControl is part of the ioProject software suite.
ioControl Command Reference
This command reference describes in detail all ioControl programming commands, or instructions. Use with form #1300, the ioControl User's Guide. ioControl is part of the ioProject software suite.
The ioControl User's Guide includes programming instructions and tips for developing control strategies to run on SNAP Ultimate controller/brains and SNAP-LCE controllers. ioControl is part of the ioProject software suite.
Caso: Soto la Marina (Spanish)
Caso sobre la automización de una planta de tratamiento de aguas en la ciudad de Soto la Marina, un puerto ubicado en la costa de Tamaulipas en el Golfo de México. (Case study of how a water treatment plant in Soto la Marina, Tamaulipas, Mexico, was automated.)
SNAP-UP1-M64 Controller/Brain Firmware
This download contains current firmware for the SNAP-UP1-M64 controller/brain.
Allen-Bradley DF1 Integration Kit for ioControl
The Allen-Bradley DF1 Integration Kit provides users of Opto 22’s ioControl software (version 6.0 and above) an easy method of communicating with Allen-Bradley drivers or PLCs using the DF1 protocol. Opto 22 controllers can act as either a “master” or a “slave” device. They can be connected directly to the serial port on an Allen-Bradley PLC or to Data Highway networks using standard Data Highway interface devices.
Controller Time Synchronization Application
This software application updates the internal clock for an Ethernet-connected Opto 22 controller. The application runs in Windows at the command prompt, and can update controller clocks regularly or just once.
This application is used with the following Opto 22 controllers:
  • SNAP PAC S- and R-Series
  • Ultimate I/O (UIO)
  • SNAP-LCE
  • SNAP-LCM4
  • M4
  • M4RTU
  • M4IO
This download is freeware. Before downloading, read the Legal Agreement.
Optomation Systems ioControl Functions
A piecewise linear interpolator function PLI under ioControl 5.1. The ioScript version can be easily copied to your program. It can be used for any of the following applications:
  • Calculating volume from tank level measurement (PV=Level Q=Volume)
  • Setpoint Generator (PV=Elapsed Time Q=Required Setpoint, eg Temp or Flow)
  • Flow rate profiling (PV=Dif Pressure Q=Flow Rate)
  • Split Range Control (PV=Common Output Q=Valve1 profile)
  • Adaptive Gain (PV=Secondary Variable Q=PID Gain Value)
SNAP Ethernet I/O BootP Server - Linux
A BootP server for configuring the IP address of the SNAP Ethernet brains and the M4SENET-100 adapter card.
