KB1424
Published: April 26, 2006
Revision: 4.0
Null string assignments not permitted after a strategy is saved and closed out of ioControl
Problem was discovered in version: R6.1a
Problem is fixed in version: R7.0a
A null sting cannot be assigned to a string variable in ioControl once a strategy has been saved, and closed out of ioControl at least once. ioControl appears to allow you to change the string to a null string in the Edit Instruction window in Configurator, but after clicking OK to save the change, the original string reappears.
