KB1429
Published: April 24, 2006
Adding a tag in OptoOPCServer Browser Configurator sometimes causes error 0xc0040008
OptoOPCServer
Problem was discovered in version: R6.1a
Problem has been resolved in version: R7.0a
You may receive an error 0xc0040008 when your client program attempts to add an item to the OptoOPCServer. If this error is returned, the port number may be missing from the configuration string when you hover over the tag with the mouse cursor using Opto Browser Configurator.
Use ioTerminal or ioControl in Configure mode to delete the strategy’s control engine name. Configure another control engine using the same name.
