KB1432
Published: April 24, 2006
Control engine change and log file name from a String Name, disables historic logging to a file in ioDisplay
ioDisplay Professional
ioDisplay Basic
Problem was discovered in version: R6.1a
Problem is fixed in version: R7.0a
In ioDisplay, historic logging is disabled to a file when a new control engine is used, and when the log file name comes from a String Name. The log file name appears in the String Name of the Historic Log File Configuration window, but logging does not take place. Logging to the default file name also does not occur. No messages are posted to the Event Log.
