KB1435
Published: April 27, 2006
Inspecting persistent variables in a Snap-LCE strategy may cause unexpected behavior
SNAP-LCE Controller Firmware
Attempts to inspect persistent variables from Debug mode in an ioControl strategy running on a Snap-LCE, may cause unexpected behavior. One of the symptoms is a delayed response from Debug mode, resulting in no variable inspection window.
[image1]
Another symptom could be the following error message:
If you are having the above symptoms, contact Opto 22 Product Support.
