KB47505
Published: April 27, 2006
Some B200 PID settings in OptoControl may affect PID scanning
Problem was discovered in version: B200 Firmware 1.19
Some PID settings in OptoControl may cause scanning to stop on a B200 PID loop. When OptoControl debug mode is used to inspect the PID, the PID Input XVAL value is blank, and the PID Output XVAL value shows the last known value in the View PID Loop window.
Opto 22 is researching this issue.
